-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   IMCO Extreme SC Upper (https://www.offshoreonly.com/forums/swap-shop/353922-imco-extreme-sc-upper.html)
hittum 05-13-2018 06:25 PM
I have a spare IMCO Extreme SC upper that has a fresh rebuild on it... This is the upper only...
Was keeping this as a spare but the boat is now for sale
$5500.00
Mike
626-833-9885
GNJ 05-13-2018 08:26 PM
Ratio and Pics?
hittum 05-13-2018 08:55 PM
All upper ratios are the same except for bravo 3's or something... I dont have pics at the moment, will have to go to shop and take some... there is NO lower included
offthefront 05-13-2018 10:21 PM
I don't think that's true on imco drives ... m
endeavour32 05-13-2018 10:49 PM
All XR uppers are the same ratio, and Imco uses XR gears in that drive. So unless some one put X gears in it, the ratio will be in the lower gear set. If you are going to put a standard Bravo lower on it, it will be a 1.50 ratio.
X Bravos and Std Bravos the ratio is made in the upper.
