@ inrecovery, the boat this setup came off had drive shafts the length of the extension boxes that went thru transom and bolt to the transmission flange. I do believe you are also correct and if the boat was setup with bravo you could possibly shorten shafts and have transmissions extend into the boxes. I guess Rik would be expert and who I would talk to if I was going to use this setup. I'm sure he knows all the fine details.
Yes you are correct, I see the flange on the inner trans plate, I was not aware of the diff. driveshaft sizes, I guess this would work on alot of diffrent hull sizes and types. Rik is the best for CS and support.
Will accept any reasonable offer, cash is king.
Will include props to make this 100% complete setup. Prop nut to transmissions and everything in between.
Originally Posted by Dean Ferry
(Post 4670539)
What style boat did they come off, where are the drives located?, and finally, can't you get an adapter for the 26 spline so you can run other props? Thanks Dean
Jammie, what size are the wheels? thanks in advance!
17X23 is stamped into prop face however they look like they were reworked.
Spring cleaning price of 20k for everything, want this stuff gone.
Originally Posted by SutphenSteph
(Post 4678998)
| All times are GMT -5. The time now is 12:23 PM. |
