Pro charger 350 Mag Mpi
ProCharger Marine Kit for 1999-2002 Mercruiser 350 Mag MPI ,$2500 plus shipping.New hoses,belt and oil included. You may need an alternator relocation bracket on some models.https://cimg2.ibsrv.net/gimg/www.off...2365ae2e01.jpg |
Includes shipping ?
Did you run this setup? If so what numbers were you seeing?
I have a '00 22ZX with the 350 Mag/Bravo1...might be interested. |
Originally Posted by _therealmattyice
(Post 4713946)
I have a '00 22ZX with the 350 Mag/Bravo1...might be interested. https://www.cpperformance.com/p-1242...0-mag-mpi.aspx |
Bump
Bump
Ttt
Anyone successfully use this on a newer model? Really narrow window. I’m assuming that the ecm is the issue. |
Originally Posted by Alwhite00
(Post 4716775)
Anyone successfully use this on a newer model? Really narrow window. I’m assuming that the ecm is the issue. ASM does this every day. Also the one bar map sensor needs to be replaced with a two bar map sensor to read the updated ECU like a factor super charged engine has. The kit from Pro Charger comes with a fuel regulator that increases fuel as needed by pulling vacuum from intake manifold. The kit is set up for a stock engine and produces 5 psi.Boost is linear and goes up the harder you push on the gas. You are not in boost all the time only when needed... My GT500 has a max boost of 14 psi,but stays at 1 to 2,unless I get into it . My Donzi has an Alpha Gen II and I'm afraid that I may blow it if I put this on.If Its doesn't sell,I'll put it on and see if the drive can handle the power,if not then I will need a Bravo one Drive ! |
I have a 2011 mpi, nobody has a kit. Just wondering if anyone has put one on a newer engine. |
