Parting tripple engine boat 540's SSM
I picked up a project that's been sitting, selling parts from it. Has triple tall deck 540's I would think around 600-625 hp each Engines are said to be 30 hours seem like as everything looks good, paint flakes off some but aside from that they look new.
I ran compression tests all are good, and ran them on hose all ran fine besides some leaks on carbs those will need gone through. These will be sold flame arrestor to pan, with msd distributors and coils, will have the wiring and throttle bracket, the bypass setup will be there, basically as seen in pics Working on getting the build sheets for them I am not sure if I will get them but here's what I do know for sure Won't let me post running videos so pm me for them. Center engine is: Merlin tall deck block Gil marine oil pan Lunati forged 4.25 crankshaft Crower I beam rods Srp forged flat top pistons Gm 088 heads Roller cams I do not know specs Retrofit roller lifters Comp cams stainless 1.7 rockers Manley pushrods Merlin 4500 marine intake 4500 dominator carb Starboard engine is: Gm performance bowtie block tall deck Gil marine oil pan 4.25 forged crank could not see name thinking callies Callies compstar I beam rods Srp forged flat top pistons Gm 088 heads Roller cams I do not know specs Retrofit roller lifters Comp cams stainless 1.7 rockers Manley pushrods Merlin 4500 marine intake 4500 dominator carb Port engine is: Merlin tall deck block Gil marine oil pan 4.25 forged crank could not see name thinking callies Callies compstar I beam rods Srp forged flat top pistons Merlin 320 cc heads 0-143c Roller cams I do not know specs Retrofit roller lifters Comp cams stainless 1.7 rockers Manley pushrods Merlin 4500 marine intake 4500 dominator carb 7500.00 each picked up 44138 Ohio Cash only in person you see what your getting and I make sure your happy with it, no warranty, I did run them and compression tested best I can do, most don't do that. Ssm parts and more... most parts are pick up I don't ship heavy stuff basillky only thing good is firewall back, all else was exposed to outdoors and beat. I have some more ssm parts from a project I grabbed, has 2 LH drives and a RH so I'm gonna do a conversion listing and more So a right and left SSMIII right and left drives 1.5 ratio, inner and outer a with trim cylinders, and a tie bar for side by side 9500.00 Extra LH drive 1.5 ratio 2750.00 Ssmiii transom assembly with trim cylinders 1200.00 72 c plug in transmissions 1200 each 72 c driveline trans 1750 Single cooler bell housings 125.00 each 8 spring ssm damper plates 150.00 each Early Hardin marine dry exhaust with tails 600.00 a set Tons of parts see pics and ask what I may have here ... https://cimg1.ibsrv.net/gimg/www.off...de37e7620.jpeg https://cimg2.ibsrv.net/gimg/www.off...51326bfca.jpeg https://cimg3.ibsrv.net/gimg/www.off...936e16dee.jpeg https://cimg4.ibsrv.net/gimg/www.off...5a7e299f2.jpeg https://cimg7.ibsrv.net/gimg/www.off...d820a3dd8.jpeg https://cimg8.ibsrv.net/gimg/www.off...669911414.jpeg https://cimg9.ibsrv.net/gimg/www.off...2c4235ccd.jpeg https://cimg0.ibsrv.net/gimg/www.off...5d623f177.jpeg https://cimg1.ibsrv.net/gimg/www.off...528d76be1.jpeg https://cimg2.ibsrv.net/gimg/www.off...f6430699e.jpeg https://cimg3.ibsrv.net/gimg/www.off...c997f0bea.jpeg https://cimg4.ibsrv.net/gimg/www.off...c89c0edf9.jpeg https://cimg5.ibsrv.net/gimg/www.off...23d0a70de.jpeg https://cimg6.ibsrv.net/gimg/www.off...adc55ea90.jpeg https://cimg7.ibsrv.net/gimg/www.off...0b7f7e218.jpeg https://cimg8.ibsrv.net/gimg/www.off...d359ea4ff.jpeg https://cimg0.ibsrv.net/gimg/www.off...ea5e70103.jpeg https://cimg1.ibsrv.net/gimg/www.off...998e77248.jpeg https://cimg3.ibsrv.net/gimg/www.off...5529c9594.jpeg https://cimg4.ibsrv.net/gimg/www.off...0f4ede350.jpeg https://cimg6.ibsrv.net/gimg/www.off...1f995a395.jpeg https://cimg7.ibsrv.net/gimg/www.off...bea6c2562.jpeg https://cimg0.ibsrv.net/gimg/www.off...42e4a9066.jpeg https://cimg1.ibsrv.net/gimg/www.off...7ac239e6e.jpeg https://cimg3.ibsrv.net/gimg/www.off...df8b3bf7c.jpeg https://cimg4.ibsrv.net/gimg/www.off...01425053e.jpeg https://cimg5.ibsrv.net/gimg/www.off...f427f0185.jpeg https://cimg6.ibsrv.net/gimg/www.off...ffa2660df.jpeg https://cimg8.ibsrv.net/gimg/www.off...984e4a537.jpeg https://cimg9.ibsrv.net/gimg/www.off...a2ccf3302.jpeg https://cimg0.ibsrv.net/gimg/www.off...9a48e484f.jpeg https://cimg3.ibsrv.net/gimg/www.off...2c447e6cc.jpeg https://cimg4.ibsrv.net/gimg/www.off...d62b2cef0.jpeg https://cimg6.ibsrv.net/gimg/www.off...63e56341b.jpeg https://cimg7.ibsrv.net/gimg/www.off...167db8001.jpeg |
im interested on the trim tabs
Trying to price them now
hi as soon as you get a $ let me know
I'm in need of (1) hydraulic trim pump for my engine hatch .......
Originally Posted by Jonathan G
(Post 4763431)
Still looking for the ssm trans mount brackets with shift cable holders...
text 440-537-8623 Im in Eastlake |
I have them I usually keep with transmissions but maybe we can work it out. 440-476-4114
got cam specs 240/[email protected] .574/.578 lift 110LSA
Someone spent a ton of $$$ on those builds.
