XR Upper 18" Input shaft
XR Upper Input shaft, for ITS ,, the shaft is 18" from end of splines to center of u-joint , oil seal area on the yoke is good cond., u-joints are tight,
$525 . includes shipping in lower 48 states https://cimg8.ibsrv.net/gimg/www.off...fa7c1cff4d.jpg https://cimg2.ibsrv.net/gimg/www.off...dfa9cdfc86.jpg |
Is this the ITS input shaft ?
I don't know,,,hopefully some here will know
[QUOTE=TxHawk;4769506]Is this the ITS input shaft ?[/QUOTE
Id say yes |
I recently bought a Mercruiser XR outdrive,, this is the upper shaft that was on it.,,It is in good condition.
if the long one is about 7.5 inches longer then the shorter one, then its ITS, I run them on my boat
I measured again,, it is 7 inches longer than a stock Bravo shaft
I just measured my ITS shaft. It is the same as what you have pictured. 18" from middle of the u-joint to the end of the splines. So anyone looking, it is an ITS assembly.
Thanks Endeavour32 for the help to identify this shaft.
If anyone can use this, ITS, input shaft with XR yoke make me a decent offer as I will not need this.
Thanks |
