Cams, bravo caps, ati balancers lots of stuff!!
2 Teague stage 4 Cams With 2 sets of their high rev short travel lifters, 2 sets of isky 9925 springs, 2 cloyes adjustable timing chain complete kits. And 2 billet timing covers with removable covers to do easy cam changes. Cams lifters and spring have under 75 hrs and the covers and cam kits have 15 hrs. $ 1000 for all. Everything in perfect condition and ready to install. Please call 978-490 5281
2 ati bbc. Balancers. Need to be painted. Work perfect $150each 2 bravo back caps 50each 4 4” thru hull tips. 100 for all 2 sets eagle 6.535 h beam rods with bearings only 15 hrs since new bushings and bearings. Good to 950hp 300/set 2 sets Hardin valve spring oilers new in packages. 100/set fountain 42 norcold fridge works great 200 1 brand new polished Teague sea strainers 300 Call or text 978-490-5281 |
Text sent for tips.
PM for spring oilers
Valve spring oilers sold
exhaust tips sold |
#6 upper 1.5 gear set in good shape. 150
#6 plug in transom assembly clean. no ring or helmet 500 #6 tail tick for plug in trans. 500 |
Parts
Timing cover ?
Would you split your cam and valve train setup? I only need one
I do have timing chain cover kits. They have a removable front cover to make for easy camshaft changes. I will break the kits up but I wanna sell everything in pairs
Timing chain cover
What kit do u have ?????
Timing chain cover
I seen cloyes my bad how much
