1-1/4" NPT Triple Common Inlet/Outlet Sea Pump Adapter
2 available @ $250 each
$429 new =AT3LQRxe1_lGFBqyVmU05fza92lCgTiaRcq2bDEmdf0UXK04K OTz4kQTNQdmW94KEITw7PmsP9MmkXt4Bj5ttwDsDD4nWkR7Q-NTU5YHi-yh_O4tsS11X4jpe-vjRAm_vdK6jgXeyCvWEibrK8cet0M_FxUtw13C4bwuuvjzhXgw-wHBt6j7AIo52_LQqSQxMI_Xg5mzCJDX8yxYiJf5tCCK6GveVQZ P0rTicwIBuQ]https://www.cpperformance.com/c-1162-inlet-outlet... 316L Stainless Steel 1-1/4" NPT At last modern technology has allowed us to again advance from a square block to an actual tuned water inlet manifold. These new cast and polished 316L Stainless Steel inlets feature staggered length and size high flow radiused inlet tubes that provide the ultimate in equal distribution provided by the massive 1-1/4"npt connection. Equal distribution to each chamber has long been a challenge that until now with modern precision flow technology and data acquisition monitoring was unavailable. Careful engineering was put into the design of both the vacuum and pressure fed characteristics, The design and configuration of the inlet allows a easy access. The inlet is tucked in tight to allow for added clearance on many applications such as Catamaran style boats.these inlets are unmatched by anything available today in modern marine cooling system. These components are designed to assist in the plumbing of your engine when using the Hardin Marine Multi-Stage sea pumps. A wide range of configurations can be created by using different inlet and outlet adapters. https://cimg2.ibsrv.net/gimg/www.off...ac2a03407d.jpg https://cimg5.ibsrv.net/gimg/www.off...18e13eb474.jpg |
triple inlet/outlet
how muts for the 2
Ed |
Originally Posted by edwin
(Post 4857168)
how muts for the 2
Ed plus shipping cause you live a bit far |
you still have these Dan? I will take them if you do...
pm sent
sold
