-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   468 rotating assy. (https://www.offshoreonly.com/forums/swap-shop/377380-468-rotating-assy.html)
jimmyzee 10-13-2022 07:15 PM
468 rotating assy.
I have a brand new rotating assy. consisting of a GM Forged Steel Crankshaft, stock length Eagle connecting rods, JE pistons 4.310 bore, Speed pro rings and Clevite bearings. Pistons are part #257981, other part numbers are in the pictures. These parts are all new never used, I was assembling a blower motor than went in a different direction. The assembly was professionally balanced by Frank Bash Engines in the Philadelphia area, I still have the receipt showing the work that was done. The crankshaft was also checked for straightness and machined for an additional .250 keyway.
$1,750.00
Jim
Hardcore1 10-19-2022 09:22 AM
Is this still available Jim?
jimmyzee 10-19-2022 07:15 PM
Hello, Yes these parts are still available, I can text you some pictures, if you would like leave your #.
jimmyzee 10-27-2022 06:13 PM
Not sure how to delete this ad but the parts have been sold thanks.
