Carson Brummett prepared complete bbc top end for turbo motor
Brodix -3 extra 332 cc oval port cnc'd heads with finish work done by Morgan Engineering Carsons head guy at the time. They are fully show polished and have a killer custom built spacer that matches the head for use on a 9.8 deck or 10-.2 deck with the fully custom built victor jr intake modified for efi and it looks totally factory if not better with fuel rails and billet cnc'd elbow thats fully polished. I have receipt for $5800 in 2013 just for the heads.
The custom built intake cost $1650 with receipt also in 2013 The elbow is cnc'd low profile oringed style Custom built stefs steel offshore style oil pan thats powdercoated gloss black with extra tabs welded to adjust belt tension Have a new Titan billet oil pump that goes with the oil pan with mount stud The pan and pump cost me $2200 with receipt in 2013 Have a new lunati turbo billet camshaft with the cast cam gear for running with cast distributor gear New Keith Black gear drive with custom crank and cam sensor brackets integrated including the sensors and also show polished. Ati balancer with the magnets built in to the timing shell to trigger the crank sensor New set of jesel .842 DLC coated lifters Carson designed efi surge tank with integrated weldon fuel pressure regulator Hardin marine oil thermostat with integrated oil filter Brand new crank trigger distributor located in shreveport, louisiana If anyone is interested in this complete set up or parts of it i will make a smoking deal for all of it... Carson also built an all aluminum 572 dart block short block for this setup but i already sold that. please call Gary at 318-470-1482 for more info and pictures if interested |
So the spacer on the heads would be used on a 10.2 deck height block and removed for use on a 9.8 deck height block, yes?
Were the heads ever run in salt water environment or fresh only? And lastly would you sell just the heads, if so where are you at on pricing. Also what are you asking for the lifters? Thanks |
Everything is brand new never been bolted on.... The intake is perfectly matched to the heads . ...Yes the intake spacer would not be used on a 9.8 deck block. Like the ad says i have receipt for $5800 just for the head in 2013... It really needs to sell with the intake... If you are really interested why dont you check what it would cost to get a set of heads as nice as these and then make me an offer... Im willing to negotiate but i cant give them away... The more you buy the better i will cut the price.. Lifters are $2045 at summit right now so let me know if your interested. thanks
Ok thanks bug. I saw where you had said you had receipts for this and that from 2013 so I just figured 11years old must be used. Anyhow I can’t afford new prices and why I search the performance parts classified’s. Good luck with your listing.
| All times are GMT -5. The time now is 01:38 PM. |
