-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Mercruiser 8.2L HO ECM PCM Module DTS 430HP computer (https://www.offshoreonly.com/forums/swap-shop/384261-mercruiser-8-2l-ho-ecm-pcm-module-dts-430hp-computer.html)
CJ240 11-21-2024 10:59 AM
For sale is Mercruiser 8.2L HO DTS ECM/PCM module / (computer)
This is a direct swap for a 8.2L MAG engine that has DTS. This 8.2L HO computer will turn any DTS Merc 8.2L 380 HP mag motor into a 430HP HO motor.
The ecm has 321 hours on it. It came out of a motor swapped 2015 Formula with an 8.2L Merc HO 430hp DTS motor. (with catalyst) If you are cat free, you can simply get the simulators.
The 8.2L HO ECM module is around $7k new and very difficult to find.
This will only work on the DTS version of the 8.2L merc.
Fantastic HP upgrade with a simple ecm swap. It's the only difference in the 380hp MAG and 430 HO 8.2L engine.
Reach out with any questions.
$2750
https://cimg6.ibsrv.net/gimg/www.off...26fb7a9fec.jpg
https://cimg9.ibsrv.net/gimg/www.off...6051c8552c.jpg
https://cimg1.ibsrv.net/gimg/www.off...66c8680360.jpg
