Bbc jessel shaft rockers 950
Hello I have a set of bbc jessel shaft rockers....FIT AFR HEADS.....going with brodix heads so these won't work...
https://cimg8.ibsrv.net/gimg/www.off...fa6517596a.jpg |
if you or who ever buys them sends them to jesel they rebuild with new bearings and reshot peen its very reasonable and fast turn around
Originally Posted by park35
(Post 4943189)
Originally Posted by JaniH
(Post 4943230)
Are these For the older or new style AFR heads
Ttt
(Post 4943237)
Ttt
(Post 4943280)
ttt
Park... just curious to know why you are swapping out your AFR 335cc heads? ... especially if they are the "Magnum" versions that are fully CNC ported and NOT the AFR 335cc "Enforcer" style of head that is an "as cast" version casted from the Chinese which is less expensive and somewhat less potent.
The AFR 335cc Magnum cnc ported version heads are a great head. Which of the Brodix castings have you decided to replace your AFR 335cc heads with?---Just curious if you are willing to share your reasons. (?) Thanks |
Originally Posted by KAAMA
(Post 4943587)
The AFR 335cc Magnum cnc ported version heads are a great head. Which of the Brodix castings have you decided to replace your AFR 335cc heads with?---Just curious if you are willing to share your reasons. (?) Thanks IDK which Brodix heads he is going to, but I had the new AFR full CNC ported 335 heads, but switched to Brodix fully ported oval 351cc and flow #s are impressive, still better than the 335, 357, and 377 AFRs. BUT they come at a premium cost, and port matched oval intake it adds up |
The less impressive 335 enforcer heads are still very capable of making great power. Out of the box they will support 1000hp with the right cam/induction. I know they are Chinese castings and much cheaper than the magnum version but can still support big numbers at a fraction of the cost of full cnc ported heads.
| All times are GMT -5. The time now is 01:35 PM. |
