-   Technical Issues (https://www.offshoreonly.com/forums/technical-issues-54/)
-   -   Brutally slow (https://www.offshoreonly.com/forums/technical-issues/188627-brutally-slow.html)
Slow Ride 06-10-2008 09:51 AM
Brutally slow
Is the change the reason for the site being brutally slow??? If so will it get better?
packinair 06-10-2008 06:26 PM
I think because of this:
Warning: Call-time pass-by-reference has been deprecated; If you would like to pass it by reference, modify the declaration of convert_bits_to_array(). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. in /var/www/www.offshoreonly.com/forums/forumdisplay.php(106) : eval()'d code on line 62
