more for the tech peeps
hidden header at the top
Warning: Call-time pass-by-reference has been deprecated; If you would like to pass it by reference, modify the declaration of convert_bits_to_array(). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. in /var/www/www.offshoreonly.com/forums/forumdisplay.php(106) : eval()'d code on line 62 |
are you still getting this error?
| All times are GMT -5. The time now is 04:08 AM. |
