-   Technical Issues (https://www.offshoreonly.com/forums/technical-issues-54/)
-   -   Tech reporting 6/19 (https://www.offshoreonly.com/forums/technical-issues/189246-tech-reporting-6-19-a.html)
JuCo 06-19-2008 02:17 PM
Tech reporting 6/19
As we mentioned in the general announcement, the tech team has made progress on the performance issues you've been experiencing. Please use this thread to report lingering problems. Thank you again for your patience and your help in tracking tech issues.
Internet Brands
MacGyver 06-19-2008 06:11 PM
I still get the error message across the top of the page.
Warning: Call-time pass-by-reference has been deprecated; If you would like to pass it by reference, modify the declaration of convert_bits_to_array(). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. in /var/www/www.offshoreonly.com/forums/forumdisplay.php(106) : eval()'d code on line 62
ibbytravel 06-19-2008 06:32 PM
Thanks for the note. We've jumped back on this monkey.
Stormybot 06-19-2008 07:29 PM
This should be fixed. Please let us know if you encounter the issue again.
MacGyver 06-19-2008 07:54 PM
Yup, The error message has disappeared. Thanks guys. I'll keep you informed of any more issues.
mikeb4 06-30-2008 12:50 AM
When I try to do a search of the forum I get this reply with an all white screen - Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 1048576 bytes) in /var/www/www.offshoreonly.com/forums/search.php on line 1033
If I do a search of a specific group within the forum I just get a blank page.
This started a week or two ago and I thought it would clear up but still has the issue. Any help?
ibbytravel 06-30-2008 12:48 PM
Mike, thanks for the post. The blank page means that the search you ran probably returned too many results. One thing you can do to limit the number of posts returned for your search is to search for only the least-common word in your query. vBulletin's search inserts an "or" in between all the words that you search for, so if even one of them appears in a post, that post will be included in the results set. Consequently, if your query has words in it that aren't that important (but that might be used commonly, like "boat" or "poker"), you'll end up with unwanted posts bloating the result set size and overrunning the limits of what the search can handle.
If you absolutely need to search for terms that are used pretty often in the boards, you'll want to used the advanced search and limit your results by, say, choosing a more restrictive time frame or searching only in particular forums. In your case it sounds like you're already restricting yourself to a single forum, so you might want to try restricting the timeframe as well.
The only realistic course of action that we can take is to start adding words to the "unsearchable" filter list, but that's still just going to give you an error message when you try to search for them. It'll just be a prettier one. Hope this helps a little bit -- sorry I can't just fix it for you.
tomcei 06-30-2008 06:37 PM
pic posting error
trying to post pics and get a error message. not a valid image file????
it's sized ok and I tried to post some pics that were used once before and still the error. played with the size and still no luck.
ibbytravel 06-30-2008 06:45 PM
What was the file extension?
tomcei 06-30-2008 07:42 PM
jpeg. just like all the others I've posted
mikeb4 07-01-2008 12:36 AM
The logic does not follow what the issue is, for example if you search using "drive shower" for only the past 3 month's in advanced search you get that error message I mentioned and an all white page. If you search just "drive" pages of results pop up ..... certainly "Drive" would return a ton more results than Drfive Shower. It seems more like it only wants one wrod searches and that wastes a lot of time paging through pages of results to find a relevant post.
Regardless this issue seems to be recent maybe even since ownership change, I have been a member for only a year but had a 100% success rate on searches for 11 month's, something has significantly changed lately in the search function. It really makes the site less useful without being able to get answers to issues by searching.
MacGyver 07-01-2008 07:08 AM
Site is slow this morning. Also, today I haven't received any email notifications on the threads I'm watching.
Stormybot 07-02-2008 05:55 PM
Testing image posting
2 Attachment(s)
Don't mind me. Just testing image posting.
Attachment 349893
Attachment 349894
Stormybot 07-02-2008 05:57 PM
tomcei,
Could I somehow get a copy of the image that you are trying to upload? I was able to upload images with .jpg and .jpeg extensions just fine. I would like to test it with yours and see if I can recreate the issue.
