Now looking for mechanic
Thanks guys for the leads on a surveyor, i'm getting things arranged. Now i guess i need a mechanic (or someone w/ engine knowledge) to look over a pair of engines & give their opinion. If anyone has recommendations in the Huffman/Houston area, let me know.
Thanks. |
Originally Posted by Baja232Brian
(Post 2449330)
Thanks. http://www.govictorymarine.com/ |
Your surveyor should be able to run the engines, compression check, etc. Last surveyor I had checked compression, silicon, brass, etc. in the oil. If your surveyor will not do this I would find one that will. If you are looking at the boat that I know you are:D then It is at a mechanics shop. I don't know much about the shop but I always had a bad feeling about the guy. Good Luck!
Originally Posted by joew.
(Post 2449482)
i know what u mean bout the bad feeling, i got that same feeling. |
Call Ed Shy @ Clear Lake Performance Power Boat. He does a lot of the work on Clear Lake Topps members boats. Great guy and very honest. 281-326-4800.
did you find one?
(Post 2467367)
did you find one?
TMR marine center llcclllclclcllc
...:evilb:...
| All times are GMT -5. The time now is 09:21 AM. |
