Chevy gear ratio change?
I have a '04 Chevy 2500HD with 6.0L/Auto/4.10 rear. I wonder if changing the rear to a 3.73 would be practical. I'm only towing 5-6K and was thinking with a 3.73 it would be a little better for every day use. The MPG sucks! I know the 3.73 was available in the regular 2500 but not the 2500HD.
Does this sound like a good idea? How much would it cost? Would I see a noticable improvement? My old truck was a 1500 5.3L/auto/3.73 and it towed good and got decent MPG. I know, don't say it.... YOU SHOULD OF GOT A DEISEL! |
Re: Chevy gear ratio change?
You would gain very little MPG when empty, and it would drop dramatically when towing. Not to mention, there's a better chance of ring & pinion failure along with transfercase and transmission failure. Plus, the money it would cost to change out the gears...
If you got 2 MPG better it would take you about 4 years to make up the cost of the gear change. |
Thanks, I figured it would not be practical to swap. I noticed that on the hwy at 70 MPH my 2500 is at about 2500 RPMs. It seemed like my 1500 w5.3/3.73 was below 2000 RPMs at 70 MPH.
Its only a 9.3% percent difference (3.73 divided by 4.11-90.75% so if you were turning 2500 it would only drop 250rpm's. You could achieve a 10 % drop by going from 30" tires to 33" tires. Hd's use a special 11.5 inch ring and pinion,the duramaxes came with 3,73 gears so the gears are available but the swap will be very exspensive,i'd probably charge 1500$ at my shop parts and labor and the dealer would easily be double that so it would take you 100,000 miles of driving just to break even,Smitty
Hey Articfriends,
Your math makes sense. I think I had bigger tires on my old truck. That makes up the difference in rpms. Dave M. |
