Re: 04 duramax with BROKEN posi
A Dodge part in a Gm product.....Oh The Horror!!!! |
Originally Posted by Knot 4 Me
This is not an unheard of failure with the Eaton locker when you push it. My guess is the dealer will do a good faith repair given it is an '04. Just don't mention the drag racing!! :D My '04 DMax will wheel hop bad if you get on it hard from a stop light so I try to keep a light foot. I know of some DMax guys that are switching over to the Dodge Trac-Right diff as it will fit into the housing no problem and is a beefier unit. Good luck!!
Originally Posted by ratman
actually all of the big three by rears from dana/spicer for thier truck lines. just dogge specs out better parts to go in thier rear ends than gm does
AF DODGE no longer uses dana they use aam, and have from 2003. the trac rite is aam and is petty good but is not a locker . if i had to pay for it it would get a elec locker likes in the power wagon. i have allready called aam right after i got my 2500 ctd . about axel and they told me it was stoung enought . i told them it better be becaus if i broke it , they would get it back on a pallet , and i would have one built they offer a 10.50 front axel also . :drink:
dana builds ford and nissian axels
Thanks for the info. I'll check mine out. DMAN2
Heres the straight scoop-I called rrp(I'm a distributer for them after doing a 3500$ buy in a few years ago) and YES,Dodge and Gm differentials are interchangeable between the 11.5 rears. The only thing offered is a factory replacement gm junk gov-lock,my cost 597$ plus s/h and a dodge true-track for 468$ plus s/h,the side bearings would have to be replaced also,18$ ea and probably not needed side races for7.76 ea. There is the straight skinny,i stand corrected but like I said earlier i haven't been into any rears in the hd diesel trucks yet. My truck goes to our local dealer monday and they have already told me they would cover it out of warranty(even though i rebuild rearends i would rather get them to buy the parts and fix it if its free),Smitty
Unbelievable: dropped truck off Yesterday at out local dealer at 12:30pm for the broken posi,told them not to fix it if warranty wouldn't cover it and if it couldn't be done by friday to pull cover inspect,order parts and refill with gear oil so i could have it this next weekend to tow my boat and that I'd pay for the oil and gasket and drive truck until they got the parts. They called today-(barely 24 hours) DONE-NO CHARGE-NEW POSI,SIDE BEARINGS,GRAPE STUFF OIL,THE WHOLE WORKS!!!!I'm embarrassed to say if someone brings a truck to my shop for a broken rearend,it takes us 2-3 days to get our parts after tearing truck down and a addittional day to put it together. GETTELS CHEVROLET, REESE MICHIGAN IS THE BEST,SMITTY
Originally Posted by Strip Poker 388
What do you think caused it????. Would that rear be the same in a 1 ton dually?
| All times are GMT -5. The time now is 02:55 PM. |
