-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Exhaust temps w/Edge chip & Duramax (https://www.offshoreonly.com/forums/trucks-trailers-transportation/109967-exhaust-temps-w-edge-chip-duramax.html)
thisistank 08-12-2005 10:57 PM
I've heard all different answers. So what's the deal?? When towing the cig up hill's the exhaust temp gets to about 1400. Is this too much? At what point does it start to melt the turbo? Will it lower the tempt to turn the chip off? Who knows these things???
thunderusone 08-12-2005 11:32 PM
Re: Exhaust temps w/Edge chip & Duramax
LB7 or LLY
dukenrock 08-13-2005 07:43 AM
I have the Banks system with a manual dial that advances the performance from 1-6, 6 being the highest. I have to turn the system down to the 1 setting while towing. The exhaust gas temp increases dramatically and I get a High Rail Pressure reading if I don't do that. It could cause damage if I would leave it higher than the number 1 setting. Does the Edge system say anything about that?
Jassman 08-13-2005 08:13 AM
I had the same chip, it definatly helps with an exhust, cat back will reduce 100 plus degrees and turbo back will be approx 140-150 and cool duals another 20 or so. An aftermarket air intake like AFE proguard is another example of more air in and getting more air out. Making more hp which is less restriction and cooler temps. Tow in the middle setting, or if Attitude no more than level 3, even when towing my 4300 I rarely saw 1300 up big hills. 1350 is max for anything longer than 15 seconds, or you will be frying something. Also the Attitude is very conservative and alot depends where you set the themometer, pre or post turbo. Good luck. Jeff
CAVelocity 08-13-2005 04:35 PM
1 Attachment(s)
1400 degrees is too hot from my understanding..... I think 1250 is as high as you want for an extended period of time (ie- towing a trailer up a hill). You definently need an exhaust system with any diesel power adder to keep temps down.
I have an 01 duramax with the old Edge "hot" Juice (125hp) that I installed along with an AFE intake and gages a few years and 40k miles ago. With the stock exhaust, it would shoot straigt toward 1400 degress without a load. With a cheap 4" to 5" exhaust with flow-through muffler, it would stay around 1250 without a load, but towing anything more than about 6000lbs I had to go back to level 1 or 2 (60-75hp) to keep the temps around 1250 degrees.
After a few months, I removed the muffler completely and replaced it with a short piece of flex pipe. Ever since then, I leave it on level 4 (125hp) without a load and level 3 (90hp) with a load. Even towing a 12500lbs boat that is 13'+ tall (see pic), you have to try real hard to get to 1250 degrees. I can tow this boat well over 80mph.
As for noise.... I installed a turn-out on the tip of the exhaust that faces towards the rear of the truck and it is actually quieter inside than it was before with the muffler. On the outside it is a different story!
thisistank 08-13-2005 04:42 PM
Thanks for the advise guys. I guess I should've included the fact that it has a full Banks Exhaust kit and K&N filter. I tow all the time in the "TOW" mode. I guess I'll just turn it completely off when I'm towing from now on.
Ptufaro 08-13-2005 05:10 PM
The book said that you should not tow anything over 6000lbs on the second setting. I have been towing my 30 Cig on the 1st level have the gauge set at 1350 (stock) no problems so-far.
Good Luck
Jassman 08-13-2005 05:11 PM
Somethings not right. Your system sounds like there is not enough flow going through it. Possibly a pluged kitty(caddlicconverter) :rolleyes: Try as an experiment, take the kitty and muffler off and put a straight pipe in, see if your temps dont drop another 100-200 degrees . Good luck :cool:
thisistank 08-13-2005 07:16 PM
Good Luck
Hmmmm, well considering I'm double that...Maybe that's the problem!! :eek:
Jassman, thanks I'll fiddle with it and see. The whole system was already installed when I bought the truck (the edge, banks, k&n etc.) The temp gauge is drilled prior to the exhaust where the book says to do so I believe.
