2004 Dodge 1500 tow rating
I may have to use a Dodge truck for a 30 mile haul (9-10K lbs).
1500 quad cab 4x4, 5.7 hemi w/ 20 inch wheels. Anyone know the ratings, or tow with this rig? |
Re: 2004 Dodge 1500 tow rating
7400 or 8400 depending on what ratio you got...
you will be over the tow rating and the gcwr of the truck towing that much.... |
Originally Posted by Sean H
................you will be over the tow rating and the gcwr of the truck towing that much....
Russ ive been towing the TG for short distances with mine and its been ok. Knock on wood. Take your time and pay attention, uphill it struggles some. I have the 3.92 ratio.
the tow rating is correct. i would just be very careful and you should be fine.waterheater what is the short distance you tow. towwing the tg seems like alot for the truck but i love it. that makes me feel better about my truck.
Originally Posted by waterheater
Will change setup in the spring.
Only if you do:eek:
Didn't need the Dodge at all. Ended up with the 2500 back this weekend afterall. Thanks for the help.
| All times are GMT -5. The time now is 12:13 AM. |
