-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Hitch Question (https://www.offshoreonly.com/forums/trucks-trailers-transportation/116209-hitch-question.html)
Boomer35 11-11-2005 06:51 AM
Hitch Question
Are all hitch's, no matter what the brand or make, equal per class... In other words are all class I's rated up to 2500, all class II 4500, all class III's 7500, and so on, and its just a matter of brand you buy based on preference not strength, (above rates just an example), looking for all the hitch info i can get to make the right choice
Steve Jr
CigDaze 11-11-2005 07:06 AM
Re: Hitch Question
That is correct...to a degree. The DOT along with SAE sets the standards for minimum strength and performance requirements. Each and every hitch, regardless of brand will perform as expected to it's rated strength, by law.
However, some manufacturers use design load cases and factors of safety above and beyond the minimum. How much, who knows? Bottom line, if you get a hitch that meets or exceeds the load criteria for your towing situation you will be fine both towing the load, and will be covered in the event of an accident.
Boomer35 11-11-2005 07:25 AM
Re: Hitch Question
Thanks Nick-
My old man said to say hello and hopes your enjoying the boat
Steve Jr
Boomer35 11-11-2005 07:43 AM
Re: Hitch Question
Where can i find each Hitch's rating, or can anybody just tell me...
buck183 11-11-2005 08:14 AM
Re: Hitch Question
Each hitch should have a sticker on it telling you it's rating.
There are generally two ratings on hitches. There will be a weight carrying rating, and a weight distributing rating.
Buck
CigDaze 11-11-2005 08:22 AM
Re: Hitch Question
Originally Posted by Boomer35
Thanks Nick-
Steve Jr
You're welcome, Steve, and a "Hello!" back at you guys.
The boat's awesome, it's been a real pleasure.
:cool:
Boomer35 11-11-2005 09:54 AM
Re: Hitch Question
i know about the 2 rating, but what are they /class?
CigDaze 11-11-2005 10:16 AM
Re: Hitch Question
Class 1
Trailer Hitch with capacity of up to 2000# gross trailer weight and 200# tongue weight.
Class 2
Trailer hitch with capacity of up to 3500# gross weight and 350# tongue weight.
Class 3
Trailer hitch with capacity of up to 5000# gross and 500# tongue weight. Also sometimes refers to a hitch with a 2" receiver regardless of rating.
Class 4
Trailer hitch with capacity of up to 10000# gross trailer weight and 1000-1400# tongue weight. Although many times any hitch with a capacity greater than 5000# gross weight is referred to as a Class 4.
Class 5
Any Trailer hitch with capacity greater than 10000# gross trailer weight and 1000-1200# tongue weight. Usually a 2.5" receiver or in some special cases a 2" receiver.
CigDaze 11-11-2005 10:28 AM
Re: Hitch Question
1 Attachment(s)
And as far as weight carrying verse weight distributing, that's a function of the vehicle and hitch combination, so there's no set value.
On My '05 F-250, for instance that came with a class 3 hitch as stock, the plate on the hitch says: "5000# Gross Trailer weight / 500# Tongue weight when weight carrying, or 12,500# / 1250# weight distributing." But it's different for each vehicle.
two-air 11-11-2005 12:40 PM
Re: Hitch Question
So with your truck could you tow a boat trailer combo up to 12500 lbs??
CigDaze 11-11-2005 01:40 PM
Re: Hitch Question
Yes, but with a weight distributing set-up only, on that stock class 3.
That's why I ditched the class 3 shown in the pic, and got a class 5, so I can tow using a plain, old weight carrying system - drop it on, lock it down and go.
two-air 11-11-2005 01:49 PM
Re: Hitch Question
Confused..
My Suburban is placarded weight carrying 5000, weight distributing 12000. I put a 10,000 lb. ball on that stock hitch.. and I tow.
Can I tow a boat trailer combo up to 10000 lbs. Or do I need to get some other kind of after market weight distributing system??
CigDaze 11-11-2005 02:03 PM
Re: Hitch Question
Confused..
Hate to say it, but you have a class 3 hitch on there! You're overweight by 2X.
Without a weight distributing hitch, you're only good to 5000!
You need to get a true class 5.
Sydwayz 11-11-2005 07:04 PM
Re: Hitch Question
See this thread:
http://www.offshoreonly.com/forums/s...vy+hitch+balls
It has ALL the info you need.
