-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Anything to winterize on trailer (https://www.offshoreonly.com/forums/trucks-trailers-transportation/117018-anything-winterize-trailer.html)
Summer Heat 11-23-2005 01:08 PM
Ok, we have our boats shut down for the season, but was wondering is there anything I need to do for a fresh water steel dual axle myco with surge to help her survive the layup?
Wally 11-23-2005 02:28 PM
Re: Anything to winterize on trailer
If possible raise the tires up off the ground so you dont get flat spots....other then that...not realy. Put a coating of wd-40 on any exposed metal that may be prone to rust and thats it....maybe put a coating of STP or some other tire dressing that blocks UV rays and she's all good
mopower 11-24-2005 09:43 AM
1 Attachment(s)
I usually repack wheel bearings after the last use of the season to get rid of any moisture that might br present. I also use tire covers from a camper supply to protect the tires from UV(it helps).
carney 11-24-2005 10:01 AM
I always jack up the axles to take any pressure off of the bearings. And put the tires back on the floor.
