-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   22.5 wheels f-350 (https://www.offshoreonly.com/forums/trucks-trailers-transportation/120198-22-5-wheels-f-350-a.html)
scarab600 01-11-2006 03:56 PM
22.5 wheels f-350
Any body have the front end leveling kit with the 22.5 wheels if so what brand kit ,where you bought wheel and tire package.The best price I have found for wheel and tire package is from USA Dually.Also all the pros and cons with this set up especially when towing.
mcraymond3 01-11-2006 06:56 PM
Re: 22.5 wheels f-350
I put them on a 2003 F350 dually. I can't remember the name brand of the lift kit but it was 2 inches. I bought the wheels from chromewheel.com and I think I paid about 4k for wheels and tires. I only towed a fishing boat (31 Jupiter) with the truck but towing did suffer from the stock set up. It sure did look good though!
JPD Motorsports 01-11-2006 08:55 PM
uhm adapters! would be the first con. if you want a true bolt on 22.5 look at the brentz more money but direct fit no adapters hub and lug centric. for a leveling kit they are all about the same. For the fords you have a couple of options like full spring replacement to a hanger kit. either of these will achieve what you want todo. with the bigger wheel setup I would also beef up the steering components a little bit as well.
