Re: 04 ford 6.0 deisel problem does chip void warranty
Ditto on the EGR. One of mine did it too.
If they are pulling the heads expect to see the cab in the air because the pull it to pull the heads in most cases.
Originally Posted by Troutly
Likely the EBP sensor (I think that is what it is called) or the EGR, or combination of both.
Mine did what you are describing and they replaced those two items. It has run fine every since. Me too on an 04'. |
they replaced heads, turbo, and several updated items no problem, they said this is very common, had no idea how many problems ford is having with the 6.0, no wonder they are changing motors
Are people who leave these 6.0's stock as Ford intended having problems?
Originally Posted by rbr2328
Yes I have had to put injectors in 4 03's in under 50k miles
I must say that ford has stood behind their warranty on all of the problems so far.
| All times are GMT -5. The time now is 06:51 PM. |
