-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   '99 GMC Sierra not going into 4 wheel drive (https://www.offshoreonly.com/forums/trucks-trailers-transportation/129130-99-gmc-sierra-not-going-into-4-wheel-drive.html)
Rookie 05-03-2006 08:57 AM
I've had this on going issue since the truck had 70,000 miles. every once in a while I would get this service 4x4 light. but when I shut off the truck it would not come back on for 6-8 months. If I tried to engage the 4x4 by pushing the button when the service light was on, it would not engage, if I turned the truck off and started it back up the light would go off and the 4x4 would work just fine.
Everyone I know who have identical trucks say they had the similar problems and the service dealers said it was the switches and had them replaced under warranty. Is this a recalled Item? Is there other simple things, vacuum lines, fuses. anything?
Jason
Sydwayz 05-03-2006 10:13 AM
Re: '99 GMC Sierra not going into 4 wheel drive
GM used several mechanisms to engage the front transfer case and hubs. It could be either that is dorking up. Some vehicles have a vacuum system, and others use an electronic solenoid plunger that engages the front system. I have seen both fail.
If you shoot a PM to R Addiction / John, he can probably tell you exactly where/what to check. He is a Mr. Goodwrench.
articfriends 05-03-2006 04:46 PM
There are 3 major components that control 4wd on the newer chevys assuming you have auto trac. Encoder motor on transfer case I see bad about 80% of time,around 450-500$ for the part,transfer case control module ,around 400-500$ for part,rarely bad,dash switch,around 45 or 50$,once in a while you get lucky and thats it, 4wd actuater on front axle,130-150$,rarely see bad ones on 99 and newer new style chevys,the old 88-mid 90's they went bad all the time and you retrofitted the new style one along with a new wiring harness. Is your truck a old style 99 or new style 99? I have a new in the box transfer case controller that DIDN'T :mad: fix a truck we thought it would that fits the 99 new style that cost us 380$ or 420$ wholesale 2 years ago if you'd like to try it,I could send it your way,Smitty
articfriends 05-03-2006 04:47 PM
If your ever in my neck of the woods I could scan it for free too,Smitty
Rookie 05-04-2006 09:05 AM
It is the new style '99. and I forgot about the scanning of the computer. I will be going down to auto zone on lunch to have it scanned for free. They have diagnosed a few things for me. I'll let you know about the transfer case controller. That just might be it, some times when I am driving around 10 mph in 2HI it will want to switch to 4LO. The light will be flashing 4LO. So I would switch it to auto-trac and get to 30mph and switch back to 2HI. This just started to happen last week.
Is there a way I can put my truck into 4x4 manully? I need to get back to my boat that is in some sand?
articfriends 05-04-2006 05:03 PM
I'm not sure if Autozones scanner reader will look at the transfer case module the same as a snapon mt-2500. If you need any further help let me know,my scanner has transmission troubleshooter which will show a path of trouble shooting and testing. The t-case module on your truck is buried deep under the dash near the firewall/top of steering column. If you pull the headlight swith panel out you can see it way in there,if you rap on it with a 3/8" extension or similar and it starts working again for a little while it is the module. There is no real way to manually get truck into 4wd other than pulling the front driveshaft then the encoder motor on t-case then rotate the shaft under neath it with something in the slot but it would be a bad idea as it holds everything in place,Smitty
