-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   trailer needs new brake system (https://www.offshoreonly.com/forums/trucks-trailers-transportation/129353-trailer-needs-new-brake-system.html)
duunoit 05-05-2006 09:40 PM
I have a South Florida trailer for my 28 Pantera. Believe it or not, it doesn't have brakes on it. The trailer is triple axle and rated for 10.5k lbs. I was looking at http://shop.easternmarine.com/
and am plannig on getting the TITAN/DICO #5237003 (it's a 10k actuator) and 4 of the Tie Down 5256153 disc brake assemblies (and putting them on the front two axles). It seems like most of the triple axle trailers I've seen only have brakes on two of the three. It looks like I can buy all of the parts (actuator, assemblies and a tubing kit) for about $900 shipped. Anybody have other suggestions?
scottc 05-05-2006 10:20 PM
Re: trailer needs new brake system
You might want to consider the ele over hydrolic actuator. Much more control and you will not have to change the tounge.
Sydwayz 05-06-2006 07:16 AM
I'd go with Kodiak disk brakes over Tie-Down and electric over hydraulic is the way to go.
Check with www.championtrailerparts.com and www.kodiaktrailer.com
happy hours 05-06-2006 07:24 AM
Ditto on the Kodiak brakes, I have had a set of the all stainless (I boat in salt water) and have loved them for the 2+ yrs I have owned them. Brakes pads are standard cheap as dirt , front wheel drive GM pads you can buy anywhere...nice touch.
duunoit 05-06-2006 08:53 AM
What do you guys think about this:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4628795663
Sydwayz 05-06-2006 01:26 PM
That is a great kit. I have never seen it packaged like that. HOWEVER, you want SS Calipers and Nickel Cadmium Rotors (or SS Rotors if you want to drop the coin).
I don't believe that eBay kit is made up of those materials. Kodiak offers them several different ways. Even in fresh water, you want the above combination I mentioned.
US1 Fountain 05-07-2006 01:56 PM
I have the Kodiak disc on my Eagle. The pads have rubbed groves into the hubs. I've been informed to grind the pad backing plate to clear.
