F-350 Headlights
3 Attachment(s)
Changed out the '01 to '04 for $120/side:
Re: F-350 Headlights
3 Attachment(s)
Closer:
Looks much cleaner. I need to do that to my '03. Where'd you get the lights? Dealer?
I bought Projector Beam APC lights for my 2000 Ford along with clear turn and corner lamps and a 2005 style grill; all on ebay. The headlights have separate high and low beams, and come with everything included, including integrated fog lights. I have mine all hooked up along with my own relay to make low beams and high beams on at the same time with my own discretion.
http://www.digitalautoz.com/ebay_ima...projectors.jpg http://dieselpowermag.com/features/f...r_ford10_s.jpg RedDog, yours looks great. I highly recommend this guy from eBay for the grill upgrade: http://cgi.ebay.com/ebaymotors/ws/eB...category=33645 |
03 is the same as the 04's
Just about all the parts are available on eBay. You will want to get 2005 and newer parts as 2004 to 2005 was the biggest change. The 2005 bumpers are a little different too, and if you buy the grill from the eBay guy I noted, he takes a factory Ford grill and trims it to properly fit a 1999-2004 bumper.
My 2002 F-350 has the newer style lights and it has more miles and they look better. FYI for what it is worth. Guess I will have to change her's out again. |
was a direct replacement no mods????
now all you need is an Excursion grill |
Turn signal/side marker is another aftermarket manufacturer (Depo), but they look identical to the O.E.M. These take about 5 minutes to change out both headlight and turn signal without any modifications. Change was made to the backing plate and headlight assembly in '05 and they are not interchangable. |
Buck |
| All times are GMT -5. The time now is 10:23 AM. |
