-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   wHICH ONE BOTH VERY NICE. (https://www.offshoreonly.com/forums/trucks-trailers-transportation/131412-one-both-very-nice.html)
TeamSaris 05-30-2006 04:05 PM
Whick one would you guys want? Which one tows better?
Built them Denali 39k 1500 37k not much difference.
TeamSaris 05-30-2006 08:09 PM
Re: wHICH ONE BOTH VERY NICE.
ttt
H20 Toie 05-30-2006 08:29 PM
Neither are a very good tow vechile unless you are towing something real light
UNSANE 05-30-2006 09:57 PM
I looked up their specs and the Denali maxes out around 8000 and depending on the engine in the 1500, you could be 7000 to 10,000 for a tow rating. If you're committed to buying a GMC, the truck with the longer wheel base would be a better tow vehicle if you're going to be close to the max rating.
Wobble 05-31-2006 07:31 AM
Is this the Denali pickup?
candyman35 05-31-2006 10:53 AM
37k for a 1500? Find another dealer. You could get a 2500HD with a diesel for a little more and be able to pull anything.
Dan
Tantrum 05-31-2006 11:17 AM
Either should pull the mini hawk just fine. :drink:
And the ladies will dig the big back seat in the Denali :evilb:
tblrklakemo 05-31-2006 09:48 PM
the denali has the LQ4 6.0 under the hood, also available in the 1500HD and 2500's. It makes 325horse in the denali and 300horse in the PU trucks. 360 ftlbs of torque in both applications. The regular 1500 has a 4.8 or a 5.3, the latter having 285 horse. The denali doesnt have a low range T-case, so that might be an issue for pulling heavy boats out of water on steep ramps but it is AWD. The transmission is going to be your week link. Both have the 4l65, so you might want to get the truck if it has 4.10 gears, or put those gears in the denali. If you need a low range t-case, well, the truck is the way to go.
TeamSaris 06-01-2006 02:07 PM
Dan
thats msrp
candyman35 06-01-2006 07:21 PM
Originally Posted by fast fun 2
thats msrp
That sounds better. How much weight are you planning to tow? Are you thinking about upgrading in the next few years?
My vote would be for the Denali if it meets your requirements. If you go with a Pickup spend a few extra dollars and get the 2500. Overkill is a good thing.
Dan
TeamSaris 06-04-2006 09:31 AM
Dan
27avanti built heavy our worktruck (1500sle shortbox regular cab) pulls it okay so a 2500 is something we dont really need. But, over kill wouldnt hurt. :D
