-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Anyone know FORD Van towing capacity? Ext. e250 3/4 tON? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/136145-anyone-know-ford-van-towing-capacity-ext-e250-3-4-ton.html)
2 Trick Rick 07-26-2006 11:53 AM
I'm looking on-line now and cant find anything, plus I called 2 ford dealers that were no help at all. I'll be towing a 29 Scarab (6300lbs) on a Aluminum double axle Continental trailer (Dont know that weight maybe 1200lbs) Most everything on-line show 7300/7500LBS with the E250 v6. I have the larger engine and 3/4Ton set up... Question is
~ Will my 2002 Ford Ext V8 3/4 Ton E250 Do this without damaging itself? I'm going down to Lake Cumberland KY and I would really like to move about the lake in something other than a 3mph house boat all week.
GoCiggie31 07-26-2006 12:32 PM
Re: Anyone know FORD Van towing capacity? Ext. e250 3/4 tON?
check this out
http://www.trailerlife.com/towratings/tr00_ford.cfm
Tony Montana 07-26-2006 06:40 PM
http://www.edmunds.com/new/2006/ford...018/specs.html
Found this for you might help :cool:
enticer 07-26-2006 08:11 PM
Same answer you got on the other site :D
Byrdman 07-31-2006 08:24 PM
Pleeeze...that van can just about handle itself....
