-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   trailer tire pressure? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/136504-trailer-tire-pressure.html)
tblrklakemo 07-30-2006 08:28 PM
do you guys fill up to the tire manufactures suggested psi on your trailer or what? What should i run? tandem axle, 3900lbs boat, dont have the wheel tire specs sorry(i think they are 15's and maybe a 235/75?)
mopower 07-30-2006 09:41 PM
Re: trailer tire pressure?
That weight may be 14 inch wheels. Check the sidewalls for tire specs. Should also have tire pressure specs. And yes , I inflate to max recommended pressure
BLAZE 07-31-2006 03:19 AM
Max psi listed on sidewall is what I always use!
tblrklakemo 07-31-2006 09:37 AM
great....i don't happen to be close to my trailer and i haven't looked at the tires/wheels since i bought it. The only reason i ask is that car manufactures and tire manufactures have different psi suggestions, so i thought the trailer manufacturer might too.
Wobble 07-31-2006 02:18 PM
Probably 35 psi but may be more if they are rated as trailer tires. I always go with the max cold psi on the side of the tire because when I am making a tight turn with my triple axle I don't want to pop a bead.
Tires run coolest at higher pressures (less flex), however, if they are wearing out in the middle of the tread then you might want to experiment with a lower pressure ( in 5lb increments)
Downtown42 07-31-2006 02:46 PM
As above, go with max cold sidewall psi. Mine are 80 max. on truck and trailer.
Strip Poker 388 07-31-2006 05:15 PM
same here 80 truck and trailer 235-85-16s'
On my old Scarab I ran 5 pounds higher because I was over the rated weight by 30 pounds each tire. trying to keep the side wall from flexing as much which creates heat
mama tryed 08-03-2006 05:13 AM
Check the tire cold, then if the sidewall says 60 lbs, put it at 60lbs. anything less causes excessive heat build up, which is the major cause of tire failure, trailer or truck.
Mitch
augie58 08-03-2006 06:53 AM
give some thought to the age of those dounuts. if they are more than 7 or 8 years old give some serious thought to replacing them. nothing ruins a good day boating more than sitting on the side of the road with a blown tire.
