-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   2005 GMC Seat belt ding (https://www.offshoreonly.com/forums/trucks-trailers-transportation/137911-2005-gmc-seat-belt-ding.html)
amarket1 08-14-2006 06:43 PM
Does anyone know if you can turn this feature off. It has finally got on my last nerve and would like to turn it off.
Wobble 08-14-2006 09:10 PM
Re: 2005 GMC Seat belt ding
You can turn it off by putting your seat belt on :drink:
R Addiction 08-14-2006 09:53 PM
Heard that...It's a pain in the azz at first but it will become second nature. :D
Jupiter Sunsation 08-14-2006 10:24 PM
I have an 01,03,04 and 05 and the 05 is the only one that makes noise!
On Fords you can press the release button on the seatbelt and the ding will stop or just wear your seatbelt!
amarket1 08-15-2006 08:27 AM
Tried the same trick like I did on my Ford. I make some short trips and leave the truck running and when I get back in and put iin drive and on my phone this dam ding go on for like 25 seconds and you cannot hear a thing. Its a real pain in the A$$.....
JPD Motorsports 08-15-2006 11:49 AM
find someone with a tech 2 I believe they can turn it off. Or goto the local wrecking yard and grab the belt piece cut the belt off and there you go just insert metal tab to seat belt no more dings.
Magic Medicine 08-15-2006 05:33 PM
Heres what you do. Plug the belt in put the strap behind your seat and tuck the seatbelt buckle and clip between the seat and the center cousel. Thats is what I do.
Or your could buy a seat belt buckle at a junk yard and just plug it into the clip.
tblrklakemo 08-15-2006 05:53 PM
ive got an 06' and i know the passenger side is weight sensitive. If the drive side is(although i dont see why it would be b/c you kinda have to have somebody drivin) just unclip the plug from underneath....otherwise you going to need to turn off the feature via PCM tune.
offshoredrillin 08-15-2006 05:58 PM
look under the seat, there is a green wire with a plug on it, just unplug it, it runs to a seat sensor...nice and simple so you dont hurt yourself in a junkyard or throw out a wishbone reaching around like crazy:D
amarket1 08-15-2006 06:51 PM
Thanks for the help guys knew I could count on yall for the help.
