-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   2004 6.0L problems ?? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/139064-2004-6-0l-problems.html)
45sonic 08-28-2006 07:12 PM
I currently have a 2004 F-350 crew cab dually with a 6.0L diesel and automatic trans. For about the past 2 or so months I have been experiencing a bucking or hesitation problem. At times I have had the truck stall on me when coming to a stop orwhen putting it in gear. It does refire but still continues to run rough. This condition does not happen all the time. The dealer has had the truck in four different times. First time was to reprogram the computer with a newer program. The next time was something to do with the ISR ???? and a fuse. We have changed fuel/water separtors 3 times and no change.
This time they are at a loss. No codes and no check engine lights.
Anyone else have the same problem??
Son of a Gun 08-28-2006 08:24 PM
Re: 2004 6.0L problems ??
Transmission?
Chris Sunkin 08-28-2006 08:39 PM
EGR valve is dirty. It's on the top of the motor right in the front. They need regular cleaning or even better, disconnect it and have a better running truck. We had a whole big string on this about a month ago
http://www.offshoreonly.com/forums/s...d.php?t=135878
Jassman 08-29-2006 05:48 AM
Correct.
NJSONIC 08-29-2006 11:08 AM
There is a pipe that needs to be cleaned out also.
BRUCE SEROFF 08-29-2006 07:37 PM
There has been a couple recalls with regard to the fuel injection module and bad injectors.
I was experiencing the same problem. Brought it in and they took care of it. I had 1 bad injector. All was covered under warranty less 100 ded. because i have 60k on the truck.
Scott Ferguson 08-29-2006 11:34 PM
I also have an 04 that had the same problems. Call me, I have an ACE mechanice at Battlefield. Scott 703-90606677
P S Mine was a turbo problem
Bigracks 08-30-2006 01:07 PM
Clean the EGR valve, then use the ford recomended fuel additive, Yes I know that I do not like using additives either, BUT SINCE i started using the ford fuel additive I have had no problems with the EGR valve sticking. 40,000 on a 05 exursinon.
AFE INTAKE, MBRP SS Exhaust, Diablo sport in tow tune.
12 mpg towing 10,00lb @ 75 mph
No tow 17mpg and thats with me racing everybody that lines up to me, it is a 8000 lb truck!! :evilb: I leave everbody in a cloud of smoke!!
DirtyMoney 08-30-2006 07:45 PM
Injectors, I have five of these and all have had injectors at least once and two of them twice now with less than 100k miles
Wobble 08-31-2006 11:15 AM
There are 99 Technical Service Bulletins out on the 6.0 powerstroke engine (at last count)
Good luck
Sydwayz 08-31-2006 11:38 AM
Good luck
"I got 99 problems and a 7-3 ain't one."
:evilb: :evilb: :evilb: :drink: :drink: :drink:
45sonic 09-01-2006 07:51 AM
Thanks all
Picked the truck up the other night after they drove it and found nothing wrong. As of right now it has not acted up. Will try the EGR disconnect next time and go from there.
Sydwayz, if you are refering to the 7.3L, I agree :D. The truck I traded in on this one was a 97 F-350 that I never had any problems with.
Zudnic 09-01-2006 05:09 PM
Originally Posted by 43Thunder
Thanks all
I started the last thread and disconnected with no problems thus far. From my experience and driving style if this did'nt fix it I would know it!
HayJay 09-01-2006 10:10 PM
Zudnic 09-07-2006 03:16 AM
Originally Posted by tee4texas
Now at 67k, its doing it again short of the smoke....but only every 3-4 days or so.
My Excursion is an 04 with 124K on it and prior to disconect had the same symptoms as you, when it started smoking the last time is when decided on a perminent solution......Still runs great and I've put on at least 10K since disconnection...........
