Corvette Question??????
Hi Everyone,
I have a 1987 Vette (former Corvette Challange Car) and I need some replacement tires for it . HERE IS THE PROBLEM.............. The size is 315/40/16, they are Michelins Z rated Can't seem to find them anywhere.... Ideas / Suggestion??? Thanks Otto |
Re: Corvette Question??????
seems to tirerack.com
if not go on corvetteforum.com |
thanks I'll try it
no not on tire rack....
The stock size for that car was a 255 50 . Do you have different wheels on it? If so how wide are they? You may have to go to stock or aftermarket rims to get a wider tire than the 255 on a 16 . American racing is showing some nice 18's with a 10 inch wide rear wheel. Price is nice too! You can do a 285 35 18 , thats pretty close.
1 Attachment(s)
I changed my 87 over to 17" wheels with 315/35/17's on the rear. I had also updated the brake system to a Grand Sport system. I also changed the brake bias spring. Being a challenge car I would have figured that would have been done already.
Try: http://cokertire.com/ they carry a large selection of older vintage tires and have a wide selection of off size 80's race tires....
Prater,
I took the 315/40/16 tires and put them on a set of stock 87 Vette rims and drive the car as a "street sleeper".....(although it only has 4000 miles on it in 18 years) now those tires need replacing and I can't find them anywhere in 16 inch....Otto |
That sounds like a race-only tire from that era.
The closest I know of is a Hoosier 275/40 or 45 that you can find on tirerack. |
The closest I know of is a Hoosier 275/40 or 45 that you can find on tirerack. Edit: Go to the Corvette forum on the web and post under the C4 section. someonel will have some tires. Wannabe |
| All times are GMT -5. The time now is 01:16 PM. |
