-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Electric over Hydraulic Brakes (https://www.offshoreonly.com/forums/trucks-trailers-transportation/151081-electric-over-hydraulic-brakes.html)
MarkDonzi 02-08-2007 06:06 PM
I've got a tri axle Myco trailer with standard surge brakes purchased new in 06. Is it a big job to add the electric over hydraulic system? and is it worth it?
wrinkleface 02-08-2007 07:05 PM
Re: Electric over Hydraulic Brakes
I have the el/hy on my 3 axle Myco and they work great. Personally I like to have "brakes on demand" if U will as compared w/ surge style! 3rd trailer w/ them. Good luck!
ACTIVESHACK 02-08-2007 07:36 PM
I dont know the conversion cost but the 2 dont even compare. I've always had surge brakes on every trailer in the past. Elec/hyd on the new triple axle Myco and i was amazed at how much better they work. You stop better with the boat in tow than you do empty.
nocigarette 02-08-2007 07:44 PM
Ijust changed my trailer over to electric brakes........They are about a 110.00 bucks a hub......440.00 tandem and 660.00 tri axle that is for parts.......
Quaid24 02-10-2007 08:44 AM
Huh?
You can't put regular electric brakes on the trailer can you? I think they have to be El/Hy because of getting wet.
I have a Myco trailer and would love to convert mine. Anybody know which manufacturer or model is best?
Sydwayz 02-10-2007 09:00 AM
Myco actually sells a conversion kit I believe.
www.championtrailerparts.com can get you anything/everything you would need for the conversion, as long as you have disc brakes already. Call into the Tech Advisers at Champion. Most of them know what they are talking about.
