-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   What boat & trailers actually weigh (https://www.offshoreonly.com/forums/trucks-trailers-transportation/155113-what-boat-trailers-actually-weigh.html)
czy40p 04-03-2007 10:51 AM
I happened to be getting the boat out of storage and then stopping by the grain elevator to pick up some fertilizer last week, when I noticed their scale was empty, so I dropped the trailer to get the combo weighed. Manufacturer specs say the boat ways 4,600 LBS, tandem steel loadmaster trailer. Before storing I pulled the drive and the battery, and topped off the 80 gallon tank. Total weight 7,180 LBS. I was a little surprised since it is 28', BBC single. I can not count the number of threads that I have seen about Will vehicle “X” pull boat “Y”? and have always wondered what the actual weight of my own boat was and thought I would share it. Does anybody have any scale numbers for their boats? I would like to see something in the 32’-38’ range. (P.S. Scale cost $5.00)
pullmytrigger 04-03-2007 11:15 AM
1 Attachment(s)
my twin sbc 29 Beek wieghs 9500 on the tandem steel trailer with 1/2 tank of fuel and all our chit for the weekend.......Fountain manual says the boat wieghs 5800 or something like that.......trailer is suppused to wiegh about 1200.......doug
boatman22 04-03-2007 11:46 AM
1 Attachment(s)
.38 special with 1/2 tank fuel, all toys and coolers on a 45' aluminum triple axle trailer: 1500 tounge. 13600lbs total:
Sydwayz 04-03-2007 01:32 PM
(old boat) 1999 Sonic 26' Prowler fully loaded; almost full tank (90 of 102 gallons), gear, anchor, tools, cockpit cover & full boat cover, spare tire; all on tandem axle aluminum Rocket trailer: 7280 lbs.
Dry weight of boat: 5050 lbs.
Fuel is 6 lbs. per gallon.
Water in your holding tanks and fresh water tanks 8 lbs. per gallon.
THEN we add subwoofers, extra batteries, amplifiers, sea strainers, mufflers... the list goes on.
I would say that at least 50% of the community has no idea how quickly and heavy everything adds up when towing; not to mention what GCWR, GAWR, weight distributing vs. weight carrying hitch; axle, wheel, and tire weight ratings; etc. etc.
czy40p 04-03-2007 01:49 PM
Thanks, I hear a lot of estimates and seems most are low. I am still surprised at the weight the trailer and the gear add to the total.
scottc 04-03-2007 04:22 PM
Formula said my F402sr1 is 10500 dry. Was told it's around 13500 with no extras:eek: Truck is 11020lbs with 1/2 tank fuel and no extras. I will be weighing the trailer and boat by this fall.
1bagger 04-03-2007 05:01 PM
1 Attachment(s)
This is from our Ontario Provincial Police mobile scale ,
2005 Ford F250 powerstroke
Front left 1100kg
Front right 1100kg
Rear left 1050 kg
Rear right 1050 kg
Truck total full full 4300kg
38 Top Gun 500hps full fuel (just pulled out of gas station)
Front left 1400 kg
Front right 1400 kg
center left 1375 kg
center right 1360 kg
rear left 1300kg
rear right 1325kg
total 12300 kg or 27,116 pounds
Surprised the hell out of me .
:eek:
Downtown42 04-04-2007 08:27 AM
Front left 1100kg
Front right 1100kg
Rear left 1050 kg
Rear right 1050 kg
Front left 1400 kg
Front right 1400 kg
center left 1375 kg
rear left 1300kg
rear right 1325kg
:eek:
About 17,600 pounds w/o the truck.
1bagger 04-04-2007 03:15 PM
The truck including tongue weight 9480
the boat/trailer 17640 . Both full of fuel .
382 newbie 04-04-2007 08:47 PM
05 382 525's 1/2 fuel 14,370 with aluminum trailer
RedDog382 04-05-2007 01:00 AM
Triple-axle steel Eagle trailer with dual spare tires for 382 Formula Fastech weighed in @ #3000 on the nose.
cig1988 04-05-2007 03:52 AM
'99 Chevy crew cab dually, tri-axle alum tralier with a Bullet 18780 lbs without drives.
