Trailer Wiring
anyone have any good trailer wiring diagrams?my wiring needs to be redone
Brown is running or clearence and tail lights. Yellow is left turn and stop . Green is right turn and stop . Blue is for elec. trailer brakes . White is ground to trailer and truck. Red if present is aux. power or batt . charge line.:drink:
Originally Posted by BAD ENOUGH
(Post 2114479)
1 Attachment(s)
Here's a chart:
Originally Posted by Sydwayz
(Post 2114507)
Blue is for reverse lights/reverse solenoid lock out for surge brakes. Electric brakes can vary depending on setup/manufacturer.
In any system use a test light to verify the wireing. I have seen way tomany misswired plugs. If you go to Draw-tite.com you will find the different plugs and how they are wired. If you still need help, I can fax over the info to you. |
here ya go
http://www.drawtite.com/6and7waywidi.html |
Black if present should be aux power.
Red if present should be reverse lights. |
thanx guys
| All times are GMT -5. The time now is 11:04 AM. |
