Electric trailer brake in new Ford SD
Has anyone had any experience with the factory installed electric trailer brake in the 08 SD? Does it work well with the electric over hydrolic trailer brakes?
Thanks! |
Doesn't work with Electic over Hydrolic, only all electric. If you hit the brakes pretty hard you will notice a little braking from the trailer. I was a little let down when we first found out.
It will work with electric over hydraulic, you need to install a brake module from carlisle. It is called a HBA-Cam controller will cost around $100.
I installed one on my manning trailer and it works like a dream and the factory brake controller is sweet. |
Depends on the model of E/H actuator. BrakeRite tested theirs on the 05-07 & 08 models without any issues, per their tech support people.
Works well with my Ausco on my Extreme Trailer.
Originally Posted by J.B. Marshall
(Post 2119733)
Originally Posted by 42MTI
(Post 2136176)
Where did you purchase it from. It sounds like you add this to your trailer, is that correct.
Thanks guys, I ordered one today off their website. This should make life much better.
382 w brake rite
Works great with Tow Command. You will be really pleased with the way the trailer is controlled. As good as air brakes !! Mine will slide all the tires with the boat on the trailer if it is set too high !! Thats stopping power
382 Newbie Are you driving an 08 Ford? Are the brakes disc?
I bought the unit in question and tried it on my 08' F450. Didn't help at all. Called the factory and they said ford and changed some things on the 08' from previous yrs and that they were working on it but no fix yet. I then found a local trailer supply company that was able to by pass PART of the factory unit and install ANOTHER controller. This works good and the factory unit isn't throwing any codes. However most places were of no help until I found this one.
Good Luck Michael |
I called Carlisle their Engineer told me theirs will not work with 08 Fords but they are working on it and Ford has not been helpful.
A Dexter Engineer told me theirs will work but you get codes that are not true. Ditto Ford's attitude Titan (Brakerite) told me that theirs works great but needs a converter box for the 08. My question to all was will they work twith 3 axels & disc brakes The Brakerite was recommended by one of the distributers that advertises on OSO and I am leaning that way. Any other input would be appreciated. |
| All times are GMT -5. The time now is 12:48 PM. |
