-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Gooseneck with SRW F250 (https://www.offshoreonly.com/forums/trucks-trailers-transportation/166716-gooseneck-srw-f250.html)
Mentalpause 08-21-2007 08:45 AM
I'd like to get opinions on getting a gooseneck trailer for the Sunsation F4 and using a new F250 SRW diesel to tow. I should be near the towing capabilities as far as weight. (15,200 lbs) My reason for SRW is I won't tow very much, and I will use the truck for other daily stuff. So I really don't want a dually for the daily stuff.
Thoughts on this - will this type of set up work ok? Boat weighs in at about 11,500 lbs.
Chris Sunkin 08-21-2007 11:56 AM
The setup is going to be borderline. For local towing it won't be bad. For running on the interstate, it won't be a comfortable, relaxed ride.
This is contingent upon the trailer being of high quality with the best components and everything in 100% order. Everywhere you skimp wil show up glowingly.
Jassman 08-21-2007 12:57 PM
Chris, how about the same set up but SRW on a 350 vs the 250..Thanks Jeff
kennyo 08-21-2007 01:40 PM
If you go crew cab/long bed maybe. the dual wheels really help on the sway factor and emergency stops.
Chris Sunkin 08-21-2007 01:45 PM
The 350 will give you sturdier componentry but the ride starts to suffer.
With any tow vehicle, length gives you ride comfort, width gives you stability and weight (mass) gives you both.
hammer01 08-21-2007 04:30 PM
Mentalpause, a buddy just upgraded from his f250 srw diesel to f350 dually shortbed and absolutely loves it. He said he feels so much more comfortable towing that it is worth the minor inconvenience of the dually daily driving and he uses it daily. BTW, he said the s.b. dually turns better than his f250 srw did. You need a dually to fit in down there at the lake anyway, it is like a Texas Cadillac. Good luck and enjoy the shootout.
Chris Sunkin 08-21-2007 08:11 PM
You have to own a dually to truly understand what a hassle they are. No bank drive thru's, no car washes. Very tough in many fast food places. You'll also be parking far out in the lot wherever you go- parking spaces seem to be shrinking anyway so they're even more less "dually friendly" There's no substitute for one out on the road though.
Sydwayz 08-21-2007 09:09 PM
I drive my dually just about everywhere. While I do find I have to plan my route a little bit more; I don't have any issues with daily driving. That's including parking/navigating downtown Washington DC. I have a little beater car that I have to force myself to drive; as I like the dually much better.
Mentalpause 08-21-2007 09:31 PM
Thanks, I have some time to think about this. Trailer would be a Myco, I am not thinking of any alternative to that.
I would only be trailering on interstates, but only a couple times a year. But never locally. The rest of the time the boat is on a lift at LOTO. Considering the few times I will trailer, I am not looking to run high speeds. Plus I am thinking to retire - so time is on my side at this point as far as being in a hurry..
If I go too far south I plan to hitch a ride with Jassman!:party-smiley-020:
CcanDo 08-21-2007 10:58 PM
IMHO with a bumper pull trailer the total load is being drug. A gooseneck trailer causes part of the load to be carried and the balance pulled.
A typical gooseneck trailer design will probably set the axles to provide a relative envelope wieght range on the ball. That wieght may far exceed the normal wieght found on the bumper pull ball.
You referanced 15,200#,If that number is the wieght of your boat and a bumper pull trailer,you may want to add 1,000# for the gooseneck trailer. However,not all 1,000# will go on the ball.
Suppose the trailer has two 8,000# axles w/ electric over hydraulic disc brakes and tires and wheels rated @ 4,000 to 4,500# each, we would have a substantial safety margin if we put 3,500 to 4,000# on the F250 gooseneck ball.(you may want the ball set 2 to 4"+/- ahead of the rear axle,otherwise known as the trunnion.)
The trailer axles will go towards the rear which causes the hitch to be heavier. The increased wheelbase will improve driveability and RIDE of the tow vehicle. Plus, the ball wieght is in the bed...Traction for the ramp will allow a two wheel drive w/positraction to rival a four wheel drive bumper pull.
I have no problem w/a F250 camper special and all the HD packages for this application.
Good Luck!
Jassman 08-22-2007 06:55 AM
Exactly, Ive got 4 dooleys and 2 3/4 srw. If it wasnt for the boat I would get rid of the dooleys, seems to be a pita lately.
Mental..the winters the time to come, great boating as long as the tides up, if not, we'll go fishin.
SinkorSwim 08-22-2007 07:14 AM
Great thoughts!!
We are in that process now of looking at tow vehicles for the next boat..
I have a 3/4 crew cab 4x4 and tow alot of construction equipment now.... but if we get the new boat I will definately switch to duallie...
Although my wife swears she will not drive it... EVER :angry-smiley-055: even though I told her chicks in big trucks are HOT :D
Mentalpause 08-22-2007 02:38 PM
Good Luck!
15,200 is the tow rating of the F250 towing gooseneck or 5th wheel. When towing with a conventional trailer the rating for the truck is 12,500 lbs.
Jass - call you later today - I am leaving in 10 minutes for the lake.
