Rail Road Dust???
what is the best way to remove it from the paint?
is it coal dust or is it oily from the exhaust?
clay bar, then usea light polishing compound by hand Tom (your good at that anhow we hear)...I had some on a ford truck I didnt see, it started rusting underneath the film :mad: had to remove kit, have the hood buffed and then reapply.
Rail dust is a bigger problem with a white vehicle then others because it stands out. The previous post was right about clay bar and a cleaner wax.
If the vehicle is under warranty take it back to the dealer- free detailing. Don't be shocked if it comes back especially on white and in salty air environments. |
what is rail road dust?
We only have wagons here:rolleyes: |
rail dust is when the cars are transported by trains, the steel wheels on the train and the iron rail of the track create friction and small amounts of hot iron dust settle on the horizontal surfaces of the car and melt in to the paint and rust, on light color car like white it looks like tiny specks reddish brown (rust) in color. the clay bars with a lubricant picks up the small iron chips on the surface and the buffing removes the rust stain left behind, i have seen it years ago so bad that you had to refinish. most vehicles are transported with plastic sheets on the horizontal surafaces this day and age so rail dust is seldom a problem but does occur.
later |
Originally Posted by augie58
(Post 2317963)
(Post 2317956)
:p
Originally Posted by later
(Post 2318351)
later |
(Post 2318368)
Thanks for the info....where can I get a clay bar??
You may try a local Auto Body Supply shop. They can usually be found in the yellow pages. |
(Post 2317963)
If the vehicle is under warranty take it back to the dealer- free detailing. Some salesmen get offended, but do you really want the Mexican outback detailing your 50k $ truck? |
Originally Posted by Joe92GT
(Post 2318476)
Have you ever seen a dealer's "detail" job. I won't let them touch my vehicles. Personally I don't like swirl marks, or burned paint.
Some salesmen get offended, but do you really want the Mexican outback detailing your 50k $ truck? Mexican might do a better job than the other |
(Post 2318368)
(Post 2318628)
napa sells the 3M one, walmart, pep boys, auto zone...when you get it cut it into blocks with a piece of wire and flatten it out, use real slippery soap/water solution, and have at it. think of it as playdoh that helps you, the flatter you make it the more it will last. most of all if the clay sticks while you are rubbing onthe hood, you need more soap/lube..slipery is good and dont press real hard, let the clay do the work...it's the equivelant of about a 4000 grit sand paper. call me if you have any issues.
playdoh |
Originally Posted by Strip Poker 388
(Post 2318653)
Can we talk about those issues:rolleyes::drink::drink:
playdoh |
(Post 2319026)
I talked to mark about your issues yesterday :D...
(Post 2319088)
My ocd or me maiking to much power for my bottom:p:D
lol, both, that and the 3 am text messages... :D |
(Post 2319167)
Had a white '00 250 that had rail dust that showed up a few months after bought. Covered under warrenty. Rust spots showed up again later and dealer couldn't cover under warranty as they said it was a new dusting condition. Clay bar is the bomb.
| All times are GMT -5. The time now is 01:59 AM. |
