Carlise trailer tires?
Registered User
Registered User
If you don't match load range properly, you'll definitely have problems. I've seen plenty of tires on trucks & trailers that were a grade or two below requirement. If you buy Marathons in D rating, your likelihood of having issues is slim. If you put C's on it, you're inviting trouble. Unlike many things, tire's don't have much of an "overhead factor" built into them. They'll usually perform up to their weight and a little more, but not much.
The BIG reason that quality tires fail is under-inflation and over-speed. The difference between 55 and 65 PSI and the difference between 65 MPH and 70 MPH mkes all the difference when it comes to tire failure. I wouldn't consider moving my trailer without hitting each tire with a gauge. Every one of my service guys checks tire pressure every day in every truck & trailer and I haven't lost a single tire in 8 years.
If you've got a big boat and 8-lugs, this is the tire to have- load range G. The RST's last forever.
http://www.goodyear.com/rv/products/g614rst.html
Aways ran Marathons with no problems. A buddy blew 2 Carlises in 1 weekend on a correctly rated trailer/tire combo. Carlisle did pay for the replacement of both trailer fenders and new tires.
My brother has a Carlisle right now with the thread bulging out away from the belts. Another mile on the road and it's be part of the pavement.
On another boating board, many guys are claiming no problem with Carlisles. And those that did, were directed to Goodyear which makes Carlisle. I don't know if that true.
i have six myco trailers on thr road averaging 1500 miles a week. i use maxxis bravo,s at 80 psi and hi-run tires at 110psi. this is just what we use. remember to always check your air pressure.
My tire had about 200 miles on it when it blew.
Replaced two rears the same time. I thought I better be safe and get new tires. Yeah right.. what a f. ing BS.
I should have kept the old once.
Thanks Chris. I just had all six tires inflated to 80 PSI before I left to Miami. THe Carlise that blew was "D" rated.
I bought the damn Carlises to match the rest. Trailer totalled, boat damage is about $50,000+ , truck near $9,000 and I lost a decade of my lifespan. (I hope not)
I think China should blow up, not tires.
Attorneys should have a field day with this I hope, I just don't have the nerves for all the legal BS.
instigator
I could be wrong, but I don't think there is a 80 psi rating on ANY *D* rated tire on this planet.... D rated are 65 psi... it's easy to see why it blew, your attorney's may turn on you...
