Ford V-10 Upgrades
Old 11-29-2007 | 09:18 PM
Originally Posted by plumbers crack
Im getting 11 mpg in mine,better check the computer.I havent touched mine yet.It pulled the 382 formula11,500 # plus trailer but swayed in the back alittle.Maybe it will pull the skater its roughly 9,000# if not I have a dually diesel anyway.Anyone pulling something big???
I fill the tank until I can see the diesel in the filler neck, drive it then divide the mileage driven by the gallons it took me to get the tank full again. I don't rely on the computer guessitmates.
Jupiter Sunsation is offline
Old 11-30-2007 | 08:29 AM
Originally Posted by Jupiter Sunsation
Did you recalibrate your speedo/odo after the new wheels?
Those would be good numbers for a diesel, they would be record setting on the V10. I have a Duramax crew cab that gets those numbers and my route trucks (two 4.3's, one 5.3) struggle to get 13 in town and both trucks have empty beds/ no weight. All of my trucks are factory stock.
Yes I checked that and my speedo is right on a couple of my friends have the gmc 2500 6.0 and can only get 13 out of them, another friend has a ford 6.0 diesel dually and he only gets around 11, while another one has a 7.3 SRW and he gets 17mpg and that we haven't used the computer to figure it just drive it sensible.
k24u is offline
Old 11-30-2007 | 05:00 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
My '03 V-10, all stock, gets 11-13mpg non towing and drops to 7 when towing. When I get bummed about how bad my fuel economy is in the truck, I take the boat out.
US1 Fountain is offline
Old 12-01-2007 | 08:32 AM
BZ's Avatar
BZ
DITTO......BZ
BZ is offline
Old 12-01-2007 | 09:46 AM
I have a 01 f250 v10 best Ive ever done was 18.7 aways easy on the take off don't hammer the peddle or they love to drink gas bad. have cold air inductive - hyper tec - dual exhaust . love the truck also if there getting bad g.p.m.try two things . 1st. disconnect battery for about 15mins than reconnect this will allow computer brain to reset . also try 91oct . but remember easy on the peddle its hard to but it pays off
tony manzella is offline
Old 12-02-2007 | 02:36 PM
That is very true if you're easy on them they are good a gas hammer at red lights and in traffic and they love gas
k24u is offline
Old 12-02-2007 | 04:16 PM
BL6
I have a '04 Excursion w/ V-10. Crossover exhaust tube was downsized at the "y" to a very restrictive diameter. Paid local muffler shop $80 to cut out & put in new Y same diameter as everything else. Noticable torque difference on hills.
Just ran from Mich to Fla over Thanksgiving. Overhead computer said 12.6 mpg avg. But if speedo read 75, my new Garmin GPS read 71, 80 on speedo was really 76 on GPS. I run stock 265 tires.
So might this also affect odometer and over (or Under?) estimate milage?
I've towed a 30' camper thru Rockies and my 35' Formula down to LOTO.
BL6 is offline
Indy
2
12-17-2007 08:33 AM
Chris
8
01-14-2007 03:14 PM
JasonSmith
Baja
25
10-03-2005 05:31 PM
26sonic
1
07-17-2003 06:49 PM
F223LS
9
03-29-2002 10:24 PM
