Im not looking for so much power necessarily, I tow occasionally and was looking for better mileage towing and just normal driving conditions. Truck only has 5200 miles on it and milege for normal driving is around 13.5 mpg. I s that right. Always was a gm owner didn't know what to expect out of this truck. Thanks Mark
what about Banks ? Guys
Originally Posted by woodington1
(Post 2384907)
Originally Posted by ninetym
(Post 2384836)
www.innovativediesel.com |
I had the Bully Dog 3 stage and was very happy. Kept it in the performance mode the whole time. EGTs got hot if pushed hard while towing a long steep incline. I would let off a little @1300 degrees.
Ford is very adept at determining engine damage done by controllers and all other aftermarket mods. They look very hard at all engine failures and LOVE to deny claims, leaving you to fight them on your own nickle. A rebuilt 6.0 is $13K. That eats up alot of fuel cost savings.
I'm not telling you not to do it, but you need to be aware of the potential downside. |
Originally Posted by Chris Sunkin
(Post 2385383)
I'm not telling you not to do it, but you need to be aware of the potential downside. This is very true, more so than with the GM's, but they are cracking down as well. If you guys are doing it for mileage, just keep it stock. if you need the extra power, use the less hp applications that keep egts in check. 1350 degrees is ok but no more than 15 seconds at a time. Some stock trucks hit this towing a steep. good luck |
Something is wrong if your only getting 13.5 not towing. Even with the ULS diesel and having K1 mixed I get 16-17mpg.
| All times are GMT -5. The time now is 03:33 PM. |
