-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Any dodge mechanics (https://www.offshoreonly.com/forums/trucks-trailers-transportation/176298-any-dodge-mechanics.html)
BY U BOY 12-29-2007 11:13 AM
Any dodge mechanics
What would cause an 02 4.7L to not idle? When its cold and i take my foot off the gas it dies and to et it to restart i have to pump the gas.
After about 20miles of driving and i stop it acts fine.
my thoughts were a bad 02 sensor or an EGR.
bgchuby01 12-29-2007 05:42 PM
I am not a dodge mechanic but most engines have a cold temp sensor that will adjust the fuel mixture to help the engine run in cold weather
Ted G 12-30-2007 12:21 PM
1 Attachment(s)
You need an Idle air control valve. About 76 bucks at Autozone.
fabricator 12-30-2007 05:02 PM
Good possibility. Also could be a dirty throttle bore. When was it last cleaned?
BY U BOY 12-31-2007 11:15 AM
Well we put a code reader on it and found out it is a large leak in the emission system. Its going to be like finding a needle in a hay stack:(
BY U BOY 12-31-2007 11:18 AM
Thanks guys ill try some of the things yall have suggested.
mikes280 12-31-2007 11:30 AM
check the air tube from the air filter to engine and check for any vacum leaks
BY U BOY 12-31-2007 12:34 PM
I checked everything i could get to yesterday. Nothing out of the ordinary.
fabricator 12-31-2007 02:21 PM
A 'large evaporative leak' means there is a large leak in the fuel vapor recovery system. This will NOT cause your stalling problem. That code is most often caused by a missing or leaking gas cap.
mikes280 12-31-2007 02:55 PM
right, but a vacum leak may cause it and would be worse when cold. does that motor have a mass air, i can't remember but i thank it does. iac motor can be stuck also .
