Powerstroke 6.0 missing
About 2 days ago noticed truck had a surging jerking to it when driving at a steady speed (not towing). Now it has a miss at idle and when driving at steady speeds, seems ok when excellerating, and seems to be better after it warms up good. Today seemed to have a rough shaking idle to it, I think its getting worse,no check engine lights or anything coming on, any ideas :confused: 04 with 50,000 miles
Is'nt that the Powerstroke kicking in!
Mine did the same thing, only at close to 150,000 miles. It was injectors, felt like a spark plug wire off on a gas engine. And it would come and go, Injectors are about 400.00 each after the core charge, and around 700.00 in labor per bank.
Where is Spilman? He has over a million trouble free miles on 1/2 dozen Powerstrokes............ This thread is blasphemy!
It could be a bad injector. Symptoms are also consistent with a bad cam position sensor. Get the codes checked. It should tell you the problem. Should be a warranty fix with only 50k.
Probably a stuck EGR. The injectors pretty much work or they don't. It's easy to clean and shut, then either search this forum or on dieselstop and look at defeating it. Depending on year ('03, some '04) you can remove a butterfly for additional benefit.
Being under warranty, you may want to have a new EGR installed, then definitely defeat it. Truck runs better and you eliminate the sticking problem. |
1 Attachment(s)
Originally Posted by Jupiter Sunsation
(Post 2460198)
ROFL:drink: |
Originally Posted by Wobble
(Post 2460545)
ROFL:drink:
Originally Posted by Chris Sunkin
(Post 2460542)
Being under warranty, you may want to have a new EGR installed, then definitely defeat it. Truck runs better and you eliminate the sticking problem. See here: http://www.offshoreonly.com/forums/s...&highlight=egr |
Chris, my injectors worked sometimes and then they didn't. It was like an intermitent miss. Did that both times, and both Ford Dealers, one in Flordia and the other time here in Jersey, said thats how injectors act when they are going bad. They said they are worse when cold, but mine were just the opposite. I found if I was easy on the truck they were fine but when pulling boats if I went over 60 or 65 they started acting up. Truck runs good with the new injectors but I still have a shaking under hard acceleration, especially when towing. Feels like the torque converter, but someone said it could be another bad injector.
Had the same exact thing happen to mine - as bowtie said, it's the injectors. Check to see if you're getting a lot of white smoke out of the tailpipe - that's another symptom.
About $3k for a set of injectors and labor, I believe. |
(Post 2460542)
Originally Posted by CigDaze
(Post 2460685)
Oh ya, forgot about that. Mine hasn't worked in a long time. ;)
Took it in today said it was needing Egr and new fuel filters, then got a call back a little later and said they had no EGR in stock so cleaned mine and test drove and it quit on diesel tech 3 blocks from dealership, frame mounted fuel pump went out. New fuel pump was put on and new filters. Seems fine now. The only thing is that the fuel pump and EGR they said was covered under warranty with $100 deductible and that if my EGR failed again they would have one in stock by then, but I will probably argue if it does anytime soon that I should not have to pay deductible again because if the EGR would of been in stock it would of been replaced also under the initial $100 deductible. I must of gotten some bad fuel as I had just had them change both fuel filters about 4,000 miles before this issue came up.
Thanks for the replies... |
1 Attachment(s)
Originally Posted by baja bailey
(Post 2461798)
Originally Posted by bowtie
(Post 2461323)
As far as your shake on hard accel, have your motor mounts checked- a common problem. Also, if you've raised the rear at all, you probably need to drop the tailshaft to get your pinion angle back to where it needs to be. The 3" factory F250 blocks raise it enough to cause the problem. |
Right Here!
(Post 2460198)
I'm busy putting more trouble-free miles on my beautiful Super Duty!!!...LOL Seriously, I replaced 3 injectors on my 99' F350 PSD @ 223k miles...and the symptoms were similar to what you described. My roofing sub has a 2000' 7.3 that has 140k and just had 2 injectors replaced. We bought that truck used in 06' & it was used for pulling horses for 93k miles so I expected to have some wear issues. Small price to pay for the best built, best towing, best all-around trucks built. |
Thanks Chris, that was my first thought, motor mounts. Then I read where someone said the shaking was normal on Fords and was the torque converter. But the tech said they aren't usually a problem. I guess I'll check motor mounts. I haven't lifted it so that isn't the problem.
1 Attachment(s)
I dropped off my '04 F550 at the dealer on Tuesday morning with 97K on her. I complained off the same symptoms that you had.
1. Sometimes 2 kicks to crank her over in the morning. Rough idle for 15 seconds with the cab shuddering back and forth. Loud knocking and greyish styrine smelling smoke. 2. The first 20 miles of rolling out, there is a "piston slap" feel like only 6 pistons are firing from 40-60 MPH. Loss of power and hesitation when you step on it. 3. Trans will not shift in to 4th sometimes when getting on to the freeway. If I pull over and stop, she will down shift/upshift fine for the rest of the drive. This is a babied work vehicle that has to be reliable everyday for me to make my appointments. Extra service and preventitive maintainance precautions have been executed. The techs still have the truck as of Friday morning with a replaced turbo and EGR valve. I was hoping for injectors after reading the cost of replacement. Trans looks like a service and shift sensor? Trans techs are still scratching their heads? Still in rental vehicle. I will keep you posted with results. Hugh |
They have a known problem with the passenger side glowplug wiring that will cause the cold-start and cold-performance problem you write of.
#2 sounds like the fuel pump. on injectors, I had one of mine in on several occasions and literally beat on them until they changed the injectors. Problem went away. You need thorough documentation considering you're 3K away from warranty end. Ford beats their dealers hard to put as little as possible into these engines under warranty repairs. It's also unusual to find a tech that truly knows what he's doing. I ended up at a dealer that does a big commercial business and sees many of these vehicles daily. |
Hey Chris Great information! I am rolling over to the dealership right now to pull some parts from the bins to complete a job today. I am going to insist on the necessary repairs. Documentation is not a problem as I save every reciept for the corporation.
I usually take the truck in for warranty service to a larger commercial based dealership that is 25 miles from me. These guys are up the street and more convienant. I understand the statement, "hard to find a tech that knows what he is doing". We handle manufacture warranty and r&d for 2 major swimming pool equipement companies. We are the only FAS station in OC to handle the warranty work. Technology has passed up alot of the swimming pool techs around here. It is hard for me to find a good employee. Also, we give our customers excellent service even if they are close to being out of their warranty. Hugh |
One of our 6.0's had injector problems at about 115K. I had every Ford printout from every visit plus a letter to their service director that I sent after every visit telling him my concerns were dismissed by his service writes (a bunch of know-nothings) and that I wasn't permitted to speak directly with the techs. Ford paid the bill.
| All times are GMT -5. The time now is 01:29 AM. |
