Questions about load ranges
I have a 2007 F250 with the factory Goodyear 20s that have a load range of E, I am looking at doing some 325/60/20 Toyo open country on new wheels but they have a load range of D. Will this matter towing a 32 foot center console? What about towing a big gooseneck trailer? Hope someone on here is familiar with load ranges and can help me out. Thanks Mike
I had the Mud Countrys on my F-250 and they were E -rated,,read the actual gvw sidewall rating on both tires and I think you'll be surprised,,Toyos have always had a higher rating compared to other manufacturers
Even the heavy duty E-load rated wheels can fail. This happened to PhantomChaos on his Excursion as one his actually cracked the wheel while towing his 382 Formula to Havasu.
You definately CANNOT skimp on the wheels. Look into wheels from www.wheelpros.com like the MotoMetals,IceMetals, Helo, as well as Welds and Mickey Thompson. |
Originally Posted by Sydwayz
(Post 2468057)
(Post 2468057)
Originally Posted by Bottomfeeder
(Post 2468055)
Oops, I read your post wrong, but also; you can't skimp on the tires either. Look into BFGoodrich All Terrain KO and the Nitto Terra Grappler as well as their brand new tire.
(Post 2468092)
Toyos in that size are rated at 3195lbs in a single wheel configuration what does it say on your Goodyears sidewall?
(Post 2468118)
| All times are GMT -5. The time now is 06:19 PM. |
