F-450 blowing fuses
I have an 08 F-450. And it keeps blowing trailer fuses for the trailer lights. I have hooked it to a few different boats and it blows it everytime. And these are new boat trailers. Any Ideas?
Buy a round-7 to flat-4 adapter.
First time was round adaptor to a 4 pin.
did the truck come with the trailer tow package? it would have both the seven pole rv and the four flat. in either case i would check the wiring schematic it is on the lid to the seven pole socket. also which fuse is it? 10 amp running lights? you could have a bad ground.
Ground can do it. If you have alot of lights the bad ground will cause a voltage drop. That makes the amps spike.
Originally Posted by mrv8outboard
(Post 2470332)
Ground would be my first guess. If not take it back to the dealer and have them check it. For now you may have to run a separate ground wire to the frame. If you need help this weekend let me know.
If you can't find it stop over my place and I'll straighten it out for ya. Or call me 410-573-9776
Bobby I'll sell u mine
Originally Posted by purnell
(Post 2474757)
| All times are GMT -5. The time now is 04:18 AM. |
