-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   '02 Duramax injectors, best price??? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/181775-02-duramax-injectors-best-price.html)
cougarman 07-19-2013 05:40 PM
Originally Posted by MINK (Post 3961615)
That's a lot of contamination if it truely is that over full with fuel, hasnt shown any signs before?
The only injectors I will put in a dmax are Exergys
That was my concern also, talking with Engineered Diesel today, and he stated at
2,500 psi per injector it doesn't take long.
Any insight or pricing on the injectors your suggesting?
Jon
Unlimited jd 07-19-2013 06:09 PM
02 lb7 runs at a minimum 4300 psi at idle. It's 23,000 at wot. I think 23,051 to be exact but I haven't data logged in a while. Bosch makes the injectors, a few companies reman them and places like engineered send nozzles to Jim at extrude hone for oversize. Stay away from GB reman injectors. I've had to do 3 sets over again.
Unlimited jd 07-19-2013 06:11 PM
Btw, it's 8 hours warranty, rushed and corners cut. To do it right, clean everything and reassemble carefully takes me almost 10 hours after doing about 30 sets.
BIGSLOW 07-22-2013 12:54 PM
Jon
Check out Lincoln Diesel Specialties for the price. $350 is about the norm they have them for $325. Make sure that they keep the boxes that they come in and ship the cores back in orginial boxes. I paid a total of $3500 for everything when I had mine done 2 years ago. The problem is the factory fuel filters are junk and let particles that are too big through whenever there is water in the fuel, which the fuel filter is supposed to filter also. Do yourself a favor and either get a lift pump installed with external filters, or for $100 bucks you can get a Nictane fuel filter adapter. It uses a CAT fuel filter that filters out finer microns, that is what I do now. As for fuel in your oil, what happened more than likely is that the injector(s) cracked and since they are under the valve cover, fuel was being dumped in the oil. This is common on the LB7 and there is not a fix for it. While they are in there, make sure they check the injector cups that the injectors sit in. Make sure they are good because later on down the road they can come loose and cause the cooling system to build pressure. Next is headgaskets. The LB7 was the first duramax and it took them a while to get it right. I have had all these problems within the last year, new injectors $3500, headgaskets, and injector cups $3500. I am hoping since I have fixed all this, that I can get at least another 150,000 out of this truck. There are plenty of common problems with these engines that they did not get right and there is nothing that you can do to prevent it. One preventable problem is pump rub, this is on your transfer case where a hole will form in the transfer case from the inside out because of a bad design. There is a pump rub kit out there that you can have installed that will fix the problem. Best thing you can do is put clean fuel in your truck and make sure to change your fuel filter every oil change or upgrade your fuel filter.
MINK 07-22-2013 02:25 PM
Jon
Roughly a set of Exergys are $2050, these come with a flow sheet proving that they are all within 3% of each other. As said a airdog lift pump/filter wouldnt be a bad idea to do at the same time, those are another few hundred dollars.
Lanceg 07-22-2013 06:06 PM
Originally Posted by 34SUTPHEN (Post 2478652)
Buizilla,
Can you also get the F-250 injs. and how much for them. Do you know how many hrs. instalation.
Thnx
not to hijack but if you need F250 injectors, I can get you a set. Are you looking for aftermarket? What motor (7.3, 6.0, 6.4?)
FIXX 07-22-2013 08:45 PM
03-10-2008, 10:52 AM #5
34SUTPHEN 34SUTPHEN is offline
My Boats:
1991 Sutphen 34
Join Date
Jan 2007
Location
grand island ny
Posts
52
Feedback Score
0
F-250 Injectors
Buizilla,
Thnx
over 3 yrs old post..i hope he got it fixed by now lol..
cougarman 07-23-2013 06:45 AM
Thanks allot for the very nice info!
Jon
cougarman 07-23-2013 06:47 AM
If I step up to Exergy's it's also a HP injector.
More fuel, more smoke.
Do I really need that for a stock application?
Jon
MINK 07-23-2013 08:01 AM
Jon
I would recommend the stock size Exergys which is what I quoted you. I agree on not wanting smoke, my personal truck (6.4 Ford) has a custom "race" tune in it that has the fuel pulled down lown and comes in progrssively like it should - runs high 12s in the 1/4mile and never puts soot on my bleech white boat, what more do I need? :)
