-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Trailer purchase help (https://www.offshoreonly.com/forums/trucks-trailers-transportation/187044-trailer-purchase-help.html)
Carguy08 05-19-2008 07:47 PM
How much should I be looking to spend for a 38 foot V bottom trailer? I dont want to spend a ton (I dont tow often) but something aluminum that will tow safely. I do need it fairly quickly. What manufactures should I check out in FLA.
t500hps 05-19-2008 07:49 PM
I've bought a 1/2 dozen from Fastload on the west coast. Decent trailers, you can upgrade them or go bare bones. Most have been built from scratch within 3-5 days of placing the order.
My best guess......38 V bottom could go from 6K to 10K.
seafordguy 05-20-2008 07:22 AM
I just bought a HI-TECH trailer out of florida through one of their local salesman.
Torsion Axles, , LED lights, Center Bunks, Disc Brakes on all 3 axles, Spare Tire & Hub Assembly, and I had him build the main beams all the way to the end of the transom so they were flush with the transom and back of the bunks - this caused an increase in the I-Beam size - so some extra $$.
I ordered it on 5/5. Last I heard they had gotten the hull layout from CIG and it was to be delivered today or tomorrow to my door.
Member Old School on here has one under his Top Gun and was happy with it so I figured if it was good enough for that boat it was good enough for mine. (Plus it was half of what a new Myco Costs)
If you want to know the cost PM me but it was a VERY fair price.
ERIC
Kims 05-20-2008 09:13 AM
I'm really happy with a Myco I found and bought on E-bay for $4K. It is a 38' and mint condition, I am sure there are more out there and used is the way to if you don't tow very much.
40magnum 05-20-2008 07:48 PM
call uhria or matt at nextrail there in ocala fl, and build a great trailer, your probley loking at 6-7k depending on options
352-572-7815
I have several trailers from them w/ no problems
good luck
Carguy08 05-20-2008 09:36 PM
Thanks a ton!! I need something quick. I'm gonna get some calls out tomarrow. All seem perfect for what im looking for.
Thanks again.
MarkSmith 05-20-2008 10:34 PM
www.mycotrailers.com
Carguy08 05-20-2008 11:20 PM
1 Attachment(s)
Originally Posted by MarkSmith (Post 2564774)
Wish I had the
Attachment 342928
seafordguy 05-21-2008 07:24 AM
I bet you are....
That's a once in a lifetime deal though...
rchevelle71 05-21-2008 08:08 AM
Try EZ Loader, not sure if they make one that big, but the one I bought for my 24 was nice, and the right price.
Jamie Bowman 05-21-2008 11:54 PM
if you want top quality from the good guys, call these guys, anything you want at the best price & see what they have done- Owen & sons 727.323.1088
florida gator 05-22-2008 11:48 AM
I had one made by Nextrail for the Donzi and it seems to be holding up very well. I had the Scarab one built by TNT in Tampa and it seems good also. It does seem to be showing a little wear on the inside of the tires so I need to call and see what may be causing that.
sleek1 05-22-2008 04:15 PM
I've been quoted $12K for a steel trailer (35' boat) , torsion axles, EOH brakes, and mounted spare.
seafordguy 05-22-2008 07:08 PM
I hope that is either from MYCO or Manning....
Kims 05-24-2008 07:24 PM
Originally Posted by seafordguy (Post 2564982)
I bet you are....
I think you are right. Spent about $60,- in seals and brake parts this spring and it works like new...
bowtye8 05-25-2008 10:25 AM
Try "Aluminum slide on" in St Pete fl.
727-323-1088
They have options from barebones to loaded.
Good quality. A step or two above a fast load.
I ordered new a fast load trip axel for 30'. It was decent for the money 5800.00.
My Alumnium slide on for my 35 was 10K loaded up with LED, full stainless bolts, elect of hydr brakes, SS brakes, etc......
Tows excellent!!
whiplash22 05-25-2008 09:02 PM
Available Trailers
I have 2 trailers for sale. One is a Boatmaster Alum trailer with all new stuff, axels, tires, wheels, brakes, and bearings. It has Led lights, power jack and power winch, and is polished. If interested I can send pictures. The price for this one is $ 6000.00
The other one is a fastload and is in great shape. This one is $5500.00.
Either one will work for a 38 V bottom. They are in PA.
We also build steel trailers but they are a lot more, around $16 to 20 thousand. PM me if interested.
SDFever 05-25-2008 10:53 PM
There is a company called South Florida Trailers if they're still in buss.. they have the nice aluminum with all stainless and bronze hardware. LED lights, rubber torsion axels, stainless calipers with cadmium rotors etc.... the way to go for salt and they stay looking nice. If they're gone, there are other builders out there that will build the same package..
Respectfully, I would not recomend Driftwood, Techsun, or Del Mar Trailers from Texas.
BDiggity 05-27-2008 04:36 PM
ERIC
lol. i came across them before seeing this post & called them early today. told him i needed one for a Cafe. He was a bit puzzled & said well im building one for a Cafe now. Got a quote, good price, but more than what i want to spend right now.
seafordguy 05-27-2008 07:28 PM
I went through a local salesman and he was cheaper delivered to my house then calling them direct would even build it.
sleek1 05-27-2008 11:25 PM
Nope, V.I.P. and Heritage both were about the same $$
CAPTAIN CHUCK 05-30-2008 09:09 AM
Don't buy from Nextrail.
I have had nothing but problems with mine.
I bought it brand new and it is crap!!!!
ChristianGott 05-30-2008 07:07 PM
i'm waiting on an aluminum tandem trailer with twin disc tortion axles from ace trailers and hitches...10% less than local products including delivery from Florida to CT.
it should be here in 2 weeks for me, but terry is in gibsonton, FL...probably could deliver to you within a couple days of 2 weeks....
danny757 03-29-2011 07:02 PM
Ace Trialer For sale 34 to 39 Dual setup mags 4950.00
I have a Ace Trialer For sale 34 to 39 Dual setup mags 4950.00 brakes on front 2 axles, call me 757-675-7005
can help with drop off near I95 from virginia to Fl or to NJ
thanks Danny
