-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Trailer bearing questions (https://www.offshoreonly.com/forums/trucks-trailers-transportation/187201-trailer-bearing-questions.html)
Sydwayz 05-21-2008 10:01 PM
Originally Posted by BY U BOY (Post 2566123)
I chedcked all the bearings and repacked at the start of season. also replaced all the bearing buddies and gave all of them 2 pumps of grease. Still slings grease.
Did you replace the rear seals with the rubber seals that have the circumference spring built into them? I have found that these are the best rear bearing seals, but they do give up over time.
Chris Sunkin 05-21-2008 10:34 PM
Bearing Buddy makes a "Spindle Seal" which is a seal with an additional o-ring and a shield. You can also convert to EZ Lube axles which eliminates the pressurized hub issue and keeps your bearings full of new, fresh grease.
BY U BOY 05-21-2008 10:53 PM
Thanks guys! I think i will pull the trailer over to McClain and have them check everything.
