Yep. Imron MSDS sheet 2, 3 & 4 as you said, once the activator is added fresh air only. Nasty.
http://www.performancecoatings.dupon...le=DirectLogin
Originally Posted by Chris Sunkin
(Post 2592425)
The only specified respirator for Imron is fresh-air supply. No filters work on cyano. This is why you can't even access information on the product on DuPont's website- they don't want anyone other than professional applicators using it. Body shop supply stores sometimes care but most often don't. they also don't sufficiently warn people about the health hazards of this stuff. If you're using it outside in a well-ventilated area, you will have way less issue.
I've been painting 25 years and I can attest to the fact that it does impair your..............Sh*t I forgot what I was saying!
Original manufactures do not clean steel enough. There is still mill scale and oil on the steel surfaces. You will have a better longer lasting finish on a blasted trailer than new. It is well worth the time and effort. Be sure to primer as soon as you can after blasting. You may consider brushing inside rails while spraying to get all the inside corners.
Originally Posted by Rage
(Post 2591145)
Has anyone repainted a trailer? If so how did you go about it or who did you have do it? Cost?
Yep....should be picking it up tomorrow. :D Some parts had to be reconstructed (the rear piece with the lights in it). Down to the metal and all re-done.....<$5K Everything! |
When I'm spraying catalyzed epoxies and polyesters I tell the neighborhood kids to get on in the house :drink:.
I friend just did his trailer with Rhinoliner. It looks awesome. He painted the fenders with urethane. |
3 Attachment(s)
(Post 2595817)
I't turned out to be around $6K, but I had to have a lot redone. New custom fenders, refabricate the rear frame (where the lights are)......lots of rust to remove. |
Turned out great Nort.
| All times are GMT -5. The time now is 01:19 AM. |
