38ft and bigger, what trailer are you using?
just wondering what brand trailer's you guy's are using on the bigger boats?
thinking about buying a new one, i know most people say Myco is the best but there are other's, in my area it is either Myco or Eagle. do you like it? what if anything would you change if you could swap it for something different? |
ask wahoo what he has..then make sure you dont get that one... cause the wheels fall off :eek:
I've got a steel Heritage triple with six wheel disc brakes. I had an Eagle and I like this better.
the eagles that I have friends with all rust out real bad. Myco is the only way to go
2 Attachment(s)
Fastload Trailers - Of Course From Florida
Less Than $9000 Delivered - 18,000 LB Disc brakes on 2-axles 16" 8-lug wheels - same as MYCO Spare rim/tire Minor Complaints - Trailer Jack Does Not Have Enough Travel - Better Supported Bow Stop Would Be Nice |
Mine is on a Fastload Aluminum. It came with the boat. It pulls perfect. It loads a lot better after adding longer foward bunks. Trailer says it has an 18k lb load capacity. My boat on the trailer weights 12,000-12,500 depending on load.
Myco
McClain Manning ...only three to consider. http://www.offshoreonly.com/forums/s...d.php?t=168781 |
We Have a Myco that we have over 7, 000 miles on, not 1 problem with it, tows 80 mph with my 38 ft Cigarette on it, i know its alot more, but u do pay for what u get !!
aluminum myco w/42 fountain on it.
2 Attachment(s)
I have had several Myco trailers and all have performed flawlessly. We currently have a painted aluminum Myco under our 39 Top Gun. There are two options that I would suggest for anybody using a trailer for more than just a few miles a year. They are electric over hydraulic brakes on all axles and a swing drive guard. I am sure that many will not agree with the drive guard, but it could save your boat and save a life! You'll just have to trust me on this one! :p
Look at Integrity trailers made here in west michigan, I have pulled some of them to florida and they pull just as nice as my Myco.
1 Attachment(s)
Myco - no complaints or issues.
3 Attachment(s)
Hard to beat a Myco.
I'm on my third and have trialered a total of over 80K miles with the three combined without a single flat tire or any failure. They are built with a nice service factor, 16 inch load range "E" tires and simply very well engineered. They are not cheap but when you can head out on a 2500 mile round trip and not have a single issue it is worth it. Do yourself a favor also and but electric over hydraulic brakes. You will be very glad you did. A good friend did the same trip we did with a larger boat on 15 inch tires and he had two blow outs and the second one took out the fender and his brake lines. It was an aluminum bolt together trailer. If you are serious about trailering and will be covering some miles don't buy on price. |
2 Attachment(s)
I have a 382 Fastech sitting on a Manning steel trailer w/electric/hyd brakes on all three axles, which by the way I think is required by law. I could not be happier with it, we have towed many good safe miles.
Have had 3 Myco's and one Eagle, Myco hands down. Have had a 38 Fountain on an Aluminum Myco and a 38 Fountain on a steel Myco. Aluminum is great if you boat in salt/brackish water. I like the steel for towing long distances. Not as much flex. Electric/hyd. brakes on at least 2 axles are a must.
MYCO is the only trailer to buy/own great product and awesome service and support
1 Attachment(s)
Have had a few diiferent brands of trailers through the years. South Florida, Myco, Fast Load, Seahawk, and now we have a Manning under the Sonic.
1 Attachment(s)
Myco
Some great looking boats on them trailers
:ernaehrung004: |
1 Attachment(s)
Here is our Myco
we have a Myco now, i have to say i don't like it as much as the Eagle we had under our 34
Myco, pulls nice,
def get elec over hyd brakes |
2 Attachment(s)
on word MYCO
Originally Posted by Sydwayz
(Post 2695227)
Myco
If I was to buy one tomorrow I'd buy a McClain.
trailer
35 ft cigarette mistress on a Myco aluminum. Pulls great. Never had a problem with anything on it.
2 Attachment(s)
get the electric over hyd for sure ,Myco,I just cant keep the alumin polished out:drink:
| All times are GMT -5. The time now is 03:33 AM. |
